Simple T1 questions?
linnea.wren
For a T1 link to 2 remote sites, our Cisco SE spec'd a 2951 with a HWIC-4T1/E1 at the remote end, and a 3925, also with a HWIC-4T1/E1 at the central site.
In considering exactly how these things are going to connect, I've come up with some (probably) simple questions. As in:
  1. Is the correct cable to connect from the demarc to the T1 card an RJ-48C cable?
  2. Is the max length for that connection 655 feet?
  3. How do I determine whether I need a crossover or a straight through cable for that connection?
  4. How do I determine if I should or should not use/configure the integrated CSU?
Our existing T1 lines are connected using 3745s with WIC/VIC-T1 cards, but these connections were set up long ago by people long gone...
vmiller
Level 7
Level 7
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
1. it can be. depends on how the carrier terminates the service in your facility
2. sounds about right. Wouldn't go any farther.
3. straight thru DCE - DTE
4. Why wouldn't you?  its pretty easy. I would think that doing an external would complicate things.
vmiller
Level 7
Level 7
Thanks, that helps...
