simulator
basefive5
Community Member
have just started training for CCNA exam pls can u get me the simulator for pratice
7 Replies 7
Please check the following link:
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Hope this helps,
HI hritter!
When u setup this Software how y could run it?i have used "-P 3600" To emulate a Cisco 3600,but doesn't work
10xs
Don't forget that this software emulates the 3600 or 7200 HW. You still need to have the Cisco IOS for one of these platforms in order to get going.
Please read the following document for more information:
http://www.ipflow.utc.fr/dynamips/README-0.2.5.txt
Hope this helps,
HI
PLZ SEND FOR ME AN IOS NAME FOR THE 7200 SERIES
10XS
REGARDS
Ali,
You can take any 7200 IOS image. Assuming you have a CCO account, you can download these images from CCO, if you don't already have one.
Hope this helps,
Hi!
i brought this IOS c3660-is-mz.122-17a.bin;AND I Issued in the command line "-P 3600".but doesn't work!how can i run it?
10xs
Ali,
Download and install dynagen.
Make sure the IOS file is in the correct directory (mostly it is Program Files\Dynamips\images)
then create a .net file and run
sample net file is below
autostart = False
model = 3660
[localhost]
ram = 160
[[ROUTER R1]]
image = \Program Files\Dynamips\images\c3660-is-mz.122-17a.bin
idlepc = 0x60d705c4
model = 3660
S2/0 = R2 s2/0
console = 2001
[[ROUTER R2]]
idlepc = 0x60d705c4
model = 3660
console = 2002
HTH, rate if it does
Narayan
