simultaneous dual wan access with nat
Olivier Joly
I have a 1841 router with two wan access from two different ISP:
1: throught dialer with fixed ip obtained from dhcp - ATM interface
2: thought fastethernet 0/1 with fixed ip and a specific gateway - can be use for Internet traffic if dialer is down.
I can't manage to make them accessible at the same time (ping and ssh).
In a second time I would like to have a VPN client access on one wan and site to site VPN on the other, instead of having the two on one wan.
Thanks in advance for your help
The sh ip route return:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, Dialer0
62.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 62.x.x.8/30 is directly connected, FastEthernet0/1
L 62.x.x.10/32 is directly connected, FastEthernet0/1
192.168.3.0/32 is subnetted, 1 subnets
S 192.168.3.1 via 0.0.0.0, Virtual-Access2
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, FastEthernet0/0
L 192.168.10.254/32 is directly connected, FastEthernet0/0
S 192.168.11.0/24 is directly connected, Tunnel0
192.168.50.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.50.0/24 is directly connected, Tunnel0
L 192.168.50.1/32 is directly connected, Tunnel0
193.x.x.0/32 is subnetted, 1 subnets
C 193.x.x.3 is directly connected, Dialer0
C 193.x.x.113 is directly connected, Dialer
I think I should have two entries for s* instead of one. I didn't find a way for it.
Please find below the config:
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
aaa new-model
aaa session-id common
dot11 syslog
no ip source-route
Ip cef
redundancy
no ip ftp passive
interface Tunnel0
ip address 192.168.50.1 255.255.255.0
tunnel source Dialer0
tunnel mode ipsec ipv4
tunnel destination x.x.x.x
tunnel path-mtu-discovery
tunnel protection ipsec profile vti
interface FastEthernet0/0
ip address 192.168.10.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
ip address 62.x.x.10 255.255.255.252
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Virtual-Template1
ip unnumbered Dialer0
interface Virtual-Template2
ip unnumbered FastEthernet0/0
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxx
ppp chap password xxx
crypto map mymap
ip local pool cabinetpool 192.168.1.1 192.168.1.10
ip local pool Vpnssladsl 192.168.3.1 192.168.3.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map routemymap interface Dialer0 overload
ip nat inside source route-map routest interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 62.x.x.9 10
ip route 192.168.11.0 255.255.255.0 Tunnel0
ip radius source-interface FastEthernet0/0
logging esm config
access-list 10 permit 192.168.10.0 0.0.0.255
access-list 10 deny any
access-list 100 remark crypto group
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 remark vpn routemymap
access-list 101 remark CCP_ACL Category=18
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.1
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.2
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.3
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.4
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.5
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.6
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.7
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.8
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.9
access-list 101 deny ip 192.168.10.0 0.0.0.255 host 192.168.1.10
access-list 101 deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 deny ip any any
access-list 110 remark crypto
access-list 110 permit ip 192.168.10.0 0.0.0.255 any
access-list 111 remark vpn routest
access-list 111 remark CCP_ACL Category=18
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.1
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.2
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.3
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.4
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.5
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.6
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.7
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.8
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.9
access-list 111 deny ip 192.168.10.0 0.0.0.255 host 192.168.2.10
access-list 111 deny ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 permit ip 192.168.10.0 0.0.0.255 any
access-list 111 deny ip any any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map routemymap permit 1
match ip address 101
match interface Dialer0
route-map routest permit 1
match interface FastEthernet0/1
line con 0
line aux 0
line vty 0 4
access-class 10 in
privilege level 15
transport input telnet
line vty 5 8
authorization exec ciscocp_vpn_xauth_ml_1
login authentication ciscocp_vpn_xauth_ml_1
transport input ssh
Hi Oliver
ok things getting clearer for me.
Can you tell me what version and feature set you are running ?
Here you are facing some diffculties with cisco routers.
1) Dialer Interface do not realy go down. so the route over d1 is allway there.
     Because it must know when to dial ... :-)
2) Simultan access over both can be done no problem
    You have it configured.
3) Access over the dialer and if this is not possible go over Fa0 can also be done.
    a) Track something over the dialer that triggers Policy Based  Routing
    b) Make a static route over d0 for one host as tracked object. and bind the default route to the tracker.
        Tracker will Trigger the dialer and install the default route when possible
4) Access to both WAN Addresses via SSH
    Yes it is possible, you need active default routes over both interfaces.
    This gives you two possible soulutions
     a) Policy Based Routing
         A Little Complex but can be handelt good
     b) VRF-Lite
         More complex ....
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html
PBR with Tracked Objects
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtpbrtrk.html
A Relativ Complete Example:
https://supportforums.cisco.com/docs/DOC-8313
From my Point of view that should do the trick
and btw route the traffic for the other office over the next hop gateway tunnel address at the remote location.
Patrick
12 Replies 12
patrick.preuss
your second route is only activ when d0 is down. The 10 in the makes the route flowting static, or in other word
a higher administraiv distance.
For the other Policy Based Routing might be a solution.
Hi Patrick,
Thank you for your reply.
I tried at first without the metric 10. However the wan2 always becomes the default route instead of wan1. The show ip route gives without the metric 10:
Gateway of last resort is 62.x.x.9 to network 0.0.0.0
S* 0.0.0.0/0 via 62.x.x.9, FastEthernet0/1
Furthermore, with this configuration, a traceroute use wan2, and the wan2 public ip does not respond to ping nor ssh.
I read on the Cisco website that the router should use the first ip route from the config, but not is my case.
I even tried to force the default route for wan1 with no luck (ip route 0.0.0.0 0.0.0.0 dialer 0 193.x.x.3). The sh ip route gave something like:
S* 0.0.0.0/0 via 193.x.x.3, dialer 0
via 62.193.44.9, FastEthernet0/1
But still using wan2
After your reply, I looked a bit into pbr as you suggested. I added ip metric +1 to wan1 route-map and ip metric +2 for wan2, but still no change.
I will check further for pbr.
In the meantime, do you have any more suggestions ?
Best regards,
Olivier
Hi Oliver
this was not what i sayed.
You should basicly have following:
1) Two route-maps
matching inside traffic
and the exit interface
2) two nats for the route-maps
this ok you have this.
then you need two default routes
ip route 0/0
ip route 0/0
No Administarive Distance or the route will not inserted.
Now everybody should have internet access.
what you see in your output is right both links are active and will be used based on load sharing rules.
Mostly per Session.
What do you mean by access at the sametime? Please provide a traceroute and or a extendet Ping (soure interface will be helpful)
Please have a look into following discussion:
https://supportforums.cisco.com/thread/2117045
Its basicly the same.
Hi oliver
one more thing
interface Tunnel0
this makes no sence.
Plese use a gateway address or inertior routing protocol.
Patrick,
From inside the clients access to Internet but through wan2. I would like the traffic going to wan1 only, and to wan2 only if wan1 is down.
I will look forward to the link you send.
By at the same time I mean I can access to ssh from outside through public ip of wan1 and wan2. However I am not sure if it is possible to do that.
About the tunnel 0, it is a vti between two offices. I understood a vti needs it's own subnet to work and encapsulate the traffic in it. The network 192.168.11.0 is the second office subnet. Maybe I misunderstand something when I set up the tunnel. However, this tunnel was always up during the differents configurations I tested.
I will give you some data after the reading...
Thanks again,
Olivier
Hi Oliver
     b) VRF-Lite
         More complex ....
Patrick
Hi Patrick,
I am running 15.1(3)T adventerprisek9-m.
After several hours of reading, and trying, now it is working !
During the process I have lost the IPSec VPN server, but the tunnel is still working.
I will post the new config during the weekend.
Thank you so much for your help, and the links.
Best regards,
Olivier
Hi Patrick,
To get this config I have used the links you gave and this one which is with nat:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
I struggled with the route-map "ToISP" because i read somewhere that we must use a match command for nat. This is right for the interfaces refering to wan but not for lan.
In the config below, the trackers are working properly, the traffic is going to IspADSL by default and to IspSDSL ifIspADSL is down.
However, and I don't know why the default interface just after rebooting is to dialer 0 and after a few minute is goes to theSDSL link. I also didn't manage to get the two default route. I have found this article which suggest to create a loopbackinterface with pbr, but it is a bit confusing for me (https://supportforums.cisco.com/thread/2067691
) and I don't know which ip I should use in my case. Do you have any example for it ?
For the tunnel, you suggest I should add the address in quote to the config :
ip route 192.168.11.0 255.255.255.0 Tunnel0 "192.168.50.2"
Should I do the same thing for dialer 0 with "10.X.X.13" ?
Thanks in advance,
Olivier
Here is the config without the crypto part:
aaa new-model
ip cef
ip domain name XXX
ip name-server 192.168.10.3
no ipv6 cef
redundancy
track 1 ip sla 1 reachability
delay down 60 up 60
track 2 ip sla 2 reachability
delay down 60 up 60
description LAN Interface
ip nat inside
ip policy route-map ToISP
duplex auto
speed auto
description To SDSL
ip address 62.X.X.10 255.255.255.252
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 8/35
interface Dialer0
description To ADSL
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname XXX
ppp chap password 7 XXX
ip http server
ip nat inside source route-map IspADSL interface Dialer0 overload
ip nat inside source route-map IspSDSL interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 62.X.X.9 track 2 # gateway provided by IspSDSL
ip sla 1
icmp-echo 193.X.X.3 # ip only reachable by IspADSL
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 62.X.X.215 # ip only reachable by IspSDSL
ip sla schedule 2 life forever start-time now
logging esm config
access-list 100 permit ip any any
route-map IspSDSL permit 1
match ip address 10
route-map IspADSL permit 1
match ip address 10
route-map ToISP permit 10
match ip address 100
set ip next-hop verify-availability 10.X.X.13 1 track 1 # First ip retruned by traceroute with IspADSL
route-map ToISP permit 20
set ip next-hop verify-availability 62.X.X.215 2 track 2 # First ip returned by traceroute with IspSDSL
end
Hi Oliver
First of all routing for dialer points allways to the interface,
because dialer are point to point.
For interfaces not point-to-point, mostly anything else please use a address to route to (Works better:-).
We deal with two points first the routing:
yes you need matches here only the source traffic and we set only the next hop or the exit interface.
so far so good.
For you tracker please add a source to the tracker, this is to keep the packets where we need them:-)
ip sla 1
icmp-echo 193.X.X.3 source dialer 1
ip sla 2
icmp-echo 62.X.X.215 source XXXX
The delay you are experience is because the tracker is assumed to be up after a reload. then you say you track it for 60 seconds down ...
Because you are using pbr (So default routing table is only the fallback) you don't need the
ip route 0.0.0.0 0.0.0.0 62.X.X.9 track 2
That you don't see both default maybe cause by the trackers.
Should be ok ...
Please remove the interface from the second one.
Please turn "ip virtual-reassembly in" of if you don't realy need it ...
Cheers Patrick
Hi Oliver
Route-maps are a great tool not only for nat. Primary they came from the Routing Tasks, PBR, Route filtering during redistribution, BGP and so on :-)
Cheers Patrick
Hi Patrick,
I applied the changes your suggested.
I don't have anymore the default route which is changing after reboot, howerver, the SDHL (fastethernet 0/1) public IP doesn't respond to ping nor ssh.
Do you have any ideas ?
Olivier
Olivier Joly
Hi Patrick,
I finally found a way to get ssh on both wan interface. Furthermore, I figured out the ToISP pbr policy wasn't working as expected, so I removed it from fastethernet0/0 and added a metric to the SDSL route.
Thanks again for the help you provided.
Here is the working config:
delay down 1 up 1
ip nat inside
duplex auto
speed auto
description To SDSL
ip nat outside
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 8/35
interface Dialer1
description To ADSL
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname
ppp chap password
ip local policy route-map IspSDSL-Redirect
ip nat inside source route-map IspADSL interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 0.0.0.0 0.0.0.0 62.x.x.9 10
ip access-list extended SSH
permit tcp host 62.x.x.10 eq 22 any
ip sla 1
icmp-echo 193.x.x.3 source-interface Dialer1
threshold 60
timeout 1000
logging esm config
match ip address 10
match ip address 10
match interface Dialer1
route-map IspSDSL-Redirect permit 10
match ip address SSL SSH
set ip next-hop 62.X.X.9
line con 0
line aux 0
line vty 0 4
access-class 10 in
authorization exec XauthRadius
login authentication XauthRadius
line vty 5 8
transport input ssh
