Router won't route (NAT)
chapmanmays
I have a router that won't route. I am swapping out one router for another, bringing up different legs of the network one at a time. The configuration is similar between the two routers.
I believe that I have tracked this down to the nat configuration, but I haven't been able to get anything to work. The router connects to an ISP using PPPoE with a dynamically assigned IP address. This is the only public interface. All the other interfaces are inside. Once the PPPoE session is established, I can ping the next hop as well as servers on Internet (DNS, Yahoo, etc.) from the router console.
What I can't do is access the Internet from a client on an internal interface. When I do show ip nat translations, there are no translations shown.
Here is most of my configuration file:
no aaa new-model
no network-clock-participate slot 2
no network-clock-participate slot 4
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.4.1
ip dhcp excluded-address 192.168.5.1
ip dhcp pool ccp-pool1
network 192.168.4.0 255.255.255.0
domain-name test.xxxx.com
dns-server 4.2.2.6 4.2.2.5
default-router 192.168.4.1
ip dhcp pool voip
import all
network 192.168.5.0 255.255.255.0
domain-name voip.xxxx.com
default-router 192.168.5.1
ip domain name xxxx.com
ip name-server 4.2.2.6
ip name-server 4.2.2.5
no ipv6 cef
voice-card 0
license udi pid CISCO3845-MB sn FOC09195YM4
username user privilege 15 secret 5 xxxx
redundancy
no ip ftp passive
interface Loopback0
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly in
ip tcp adjust-mss 1452
shutdown
duplex auto
speed auto
media-type rj45
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.1
description $ETH-LAN$
encapsulation dot1Q 400
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.2
encapsulation dot1Q 500
ip address 192.168.5.1 255.255.255.0
ip nat inside
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface ATM1/0
no ip address
shutdown
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface FastEthernet4/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname pppoe
ppp chap password 0 pppoepppoe
ppp pap sent-username pppoe password 0 pppoepppoe
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool pool2
no ipv6 cef
voice-card 0
redundancy
no ip ftp passive
interface Loopback0
no ip address
duplex auto
speed auto
media-type rj45
no ip address
duplex auto
speed auto
media-type rj45
ip nat inside
ip nat inside
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip http server
Giuseppe Larosa
Hello Chapman,
in order to have NAT working you need a global statement like the following
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.4.0 0.0.0.255
Up to now you have just declared what interface is NAT  inside and what interface is NAT outside (dialer1) but this is not enough.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Chapman,
Hope to help
Giuseppe
I don't see how I missed that one! It was in the original configuration, just buried. Thanks for your help!
