site to site VPN not working with this error
shiran.wang
Cisco UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2
site to site VPN did not working with this error.
site_A
003591: *Oct 22 16:22:13.241: ISAKMP: set new node 0 to QM_IDLE
003592: *Oct 22 16:22:13.241: ISAKMP:(0):SA is still budding. Attached new ipsec request to it. (local 182.93.2x.x, remote 183.63.x.x)
003593: *Oct 22 16:22:13.241: ISAKMP: Error while processing SA request: Failed to initialize SA
003594: *Oct 22 16:22:13.241: ISAKMP: Error while processing KMI message 0, error 2.
003595: *Oct 22 16:22:13.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003596: *Oct 22 16:22:13.241: ISAKMP (0): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
003597: *Oct 22 16:22:13.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003598: *Oct 22 16:22:13.241: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003599: *Oct 22 16:22:13.241: ISAKMP:(0):Sending an IKE IPv4 Packet.....
Success rate is 0 percent (0/5)
CPKMOCME#
003600: *Oct 22 16:22:23.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003601: *Oct 22 16:22:23.241: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
003602: *Oct 22 16:22:23.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003603: *Oct 22 16:22:23.241: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003604: *Oct 22 16:22:23.241: ISAKMP:(0):Sending an IKE IPv4 Packet.
003605: *Oct 22 16:22:33.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003606: *Oct 22 16:22:33.241: ISAKMP (0): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
003607: *Oct 22 16:22:33.241: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003608: *Oct 22 16:22:33.241: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003609: *Oct 22 16:22:33.241: ISAKMP:(0):Sending an IKE IPv4 Packet.
003610: *Oct 22 16:22:43.242: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003611: *Oct 22 16:22:43.242: ISAKMP:(0):peer does not do paranoid keepalives.
003612: *Oct 22 16:22:43.242: ISAKMP:(0):deleting SA reason "Death by retransmission P1" state (I) MM_NO_STATE (peer 183.63.x.x)
003613: *Oct 22 16:22:43.242: ISAKMP:(0):deleting SA reason "Death by retransmission P1" state (I) MM_NO_STATE (peer 183.63.x.x)
003614: *Oct 22 16:22:43.242: ISAKMP: Unlocking peer struct 0x86019068 for isadb_mark_sa_deleted(), count 0
003615: *Oct 22 16:22:43.242: ISAKMP: Deleting peer node by peer_reap for 183.63.x.x: 86019068
003616: *Oct 22 16:22:43.242: ISAKMP:(0):deleting node -924415756 error FALSE reason "IKE deleted"
003617: *Oct 22 16:22:43.242: ISAKMP:(0):deleting node -11328370 error FALSE reason "IKE deleted"
003618: *Oct 22 16:22:43.242: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
003619: *Oct 22 16:22:43.242: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_DEST_SA
003620: *Oct 22 16:22:46.386: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (N) NEW SA
003621: *Oct 22 16:22:46.386: ISAKMP: Created a peer struct for 183.63.x.x, peer port 500
003622: *Oct 22 16:22:46.386: ISAKMP: New peer created peer = 0x86019068 peer_handle = 0x80000079
003623: *Oct 22 16:22:46.386: ISAKMP: Locking peer struct 0x86019068, refcount 1 for crypto_isakmp_process_block
003624: *Oct 22 16:22:46.386: ISAKMP: local port 500, remote port 500
003625: *Oct 22 16:22:46.386: ISAKMP:(0):insert sa successfully sa = 8A8F4A4C
003626: *Oct 22 16:22:46.386: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
003627: *Oct 22 16:22:46.386: ISAKMP:(0):Old State = IKE_READY  New State = IKE_R_MM1
003628: *Oct 22 16:22:46.390: ISAKMP:(0): processing SA payload. message ID = 0
003629: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003630: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
003631: *Oct 22 16:22:46.390: ISAKMP (0): vendor ID is NAT-T RFC 3947
003632: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003633: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
003634: *Oct 22 16:22:46.390: ISAKMP (0): vendor ID is NAT-T v7
003635: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003636: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
003637: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID is NAT-T v3
003638: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003639: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
003640: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID is NAT-T v2
003641: *Oct 22 16:22:46.390: ISAKMP:(0):found peer pre-shared key matching 183.63.x.x
003642: *Oct 22 16:22:46.390: ISAKMP:(0): local preshared key found
003643: *Oct 22 16:22:46.390: ISAKMP : Scanning profiles for xauth ...
003644: *Oct 22 16:22:46.390: ISAKMP:(0):Checking ISAKMP transform 1 against priority 1 policy
003645: *Oct 22 16:22:46.390: ISAKMP:      encryption 3DES-CBC
003646: *Oct 22 16:22:46.390: ISAKMP:      hash SHA
003647: *Oct 22 16:22:46.390: ISAKMP:      default group 5
003648: *Oct 22 16:22:46.390: ISAKMP:      auth pre-share
003649: *Oct 22 16:22:46.390: ISAKMP:      life type in seconds
003650: *Oct 22 16:22:46.390: ISAKMP:      life duration (basic) of 3600
003651: *Oct 22 16:22:46.390: ISAKMP:(0):atts are acceptable. Next payload is 3
003652: *Oct 22 16:22:46.390: ISAKMP:(0):Acceptable atts:actual life: 0
003653: *Oct 22 16:22:46.390: ISAKMP:(0):Acceptable atts:life: 0
003654: *Oct 22 16:22:46.390: ISAKMP:(0):Basic life_in_seconds:3600
003655: *Oct 22 16:22:46.390: ISAKMP:(0):Returning Actual lifetime: 3600
003656: *Oct 22 16:22:46.390: ISAKMP:(0)::Started lifetime timer: 3600.
003657: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003658: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
003659: *Oct 22 16:22:46.390: ISAKMP (0): vendor ID is NAT-T RFC 3947
003660: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003661: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
003662: *Oct 22 16:22:46.390: ISAKMP (0): vendor ID is NAT-T v7
003663: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003664: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
003665: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID is NAT-T v3
003666: *Oct 22 16:22:46.390: ISAKMP:(0): processing vendor id payload
003667: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
003668: *Oct 22 16:22:46.390: ISAKMP:(0): vendor ID is NAT-T v2
003669: *Oct 22 16:22:46.394: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
003670: *Oct 22 16:22:46.394: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM1
003671: *Oct 22 16:22:46.394: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
003672: *Oct 22 16:22:46.394: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003673: *Oct 22 16:22:46.394: ISAKMP:(0):Sending an IKE IPv4 Packet.
003674: *Oct 22 16:22:46.394: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
003675: *Oct 22 16:22:46.394: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM2
003676: *Oct 22 16:22:56.382: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
003677: *Oct 22 16:22:56.382: ISAKMP:(0): phase 1 packet is a duplicate of a previous packet.
003678: *Oct 22 16:22:56.382: ISAKMP:(0): retransmitting due to retransmit phase 1
003679: *Oct 22 16:22:56.882: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003680: *Oct 22 16:22:56.882: ISAKMP (0): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
003681: *Oct 22 16:22:56.882: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP
003682: *Oct 22 16:22:56.882: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003683: *Oct 22 16:22:56.882: ISAKMP:(0):Sending an IKE IPv4 Packet.
003684: *Oct 22 16:23:06.383: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
003685: *Oct 22 16:23:06.383: ISAKMP:(0): phase 1 packet is a duplicate of a previous packet.
003686: *Oct 22 16:23:06.383: ISAKMP:(0): retransmitting due to retransmit phase 1
003687: *Oct 22 16:23:06.883: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003688: *Oct 22 16:23:06.883: ISAKMP (0): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
003689: *Oct 22 16:23:06.883: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP
003690: *Oct 22 16:23:06.883: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003691: *Oct 22 16:23:06.883: ISAKMP:(0):Sending an IKE IPv4 Packet.
003692: *Oct 22 16:23:16.383: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
003693: *Oct 22 16:23:16.383: ISAKMP:(0): phase 1 packet is a duplicate of a previous packet.
003694: *Oct 22 16:23:16.383: ISAKMP:(0): retransmitting due to retransmit phase 1
003695: *Oct 22 16:23:16.883: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003696: *Oct 22 16:23:16.883: ISAKMP (0): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
003697: *Oct 22 16:23:16.883: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP
003698: *Oct 22 16:23:16.883: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003699: *Oct 22 16:23:16.883: ISAKMP:(0):Sending an IKE IPv4 Packet.
003700: *Oct 22 16:23:26.384: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
003701: *Oct 22 16:23:26.384: ISAKMP:(0): phase 1 packet is a duplicate of a previous packet.
003702: *Oct 22 16:23:26.384: ISAKMP:(0): retransmitting due to retransmit phase 1
003703: *Oct 22 16:23:26.884: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003704: *Oct 22 16:23:26.884: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
003705: *Oct 22 16:23:26.884: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP
003706: *Oct 22 16:23:26.884: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003707: *Oct 22 16:23:26.884: ISAKMP:(0):Sending an IKE IPv4 Packet.
003708: *Oct 22 16:23:33.244: ISAKMP:(0):purging node -924415756
003709: *Oct 22 16:23:33.244: ISAKMP:(0):purging node -11328370
003710: *Oct 22 16:23:36.384: ISAKMP (0): received packet from 183.63.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
003711: *Oct 22 16:23:36.384: ISAKMP:(0): phase 1 packet is a duplicate of a previous packet.
003712: *Oct 22 16:23:36.384: ISAKMP:(0): retransmitting due to retransmit phase 1
003713: *Oct 22 16:23:36.884: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003714: *Oct 22 16:23:36.884: ISAKMP (0): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
003715: *Oct 22 16:23:36.884: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP
003716: *Oct 22 16:23:36.884: ISAKMP:(0): sending packet to 183.63.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
003717: *Oct 22 16:23:36.884: ISAKMP:(0):Sending an IKE IPv4 Packet.
003718: *Oct 22 16:23:43.244: ISAKMP:(0):purging SA., sa=878F0118, delme=878F0118
003719: *Oct 22 16:23:46.884: ISAKMP:(0): retransmitting phase 1 MM_SA_SETUP...
003720: *Oct 22 16:23:46.884: ISAKMP:(0):peer does not do paranoid keepalives.
003721: *Oct 22 16:23:46.884: ISAKMP:(0):deleting SA reason "Death by retransmission P1" state (R) MM_SA_SETUP (peer 183.63.x.x)
003722: *Oct 22 16:23:46.884: ISAKMP:(0):deleting SA reason "Death by retransmission P1" state (R) MM_SA_SETUP (peer 183.63.x.x)
003723: *Oct 22 16:23:46.884: ISAKMP: Unlocking peer struct 0x86019068 for isadb_mark_sa_deleted(), count 0
003724: *Oct 22 16:23:46.884: ISAKMP: Deleting peer node by peer_reap for 183.63.x.x: 86019068
003725: *Oct 22 16:23:46.884: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
003726: *Oct 22 16:23:46.884: ISAKMP:(0):Old State = IKE_R_MM2  New State = IKE_DEST_SA
site_B
Sending 5, 100-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.20.1
003605: ISAKMP:(0): SA request profile is (NULL)
003606: ISAKMP: Created a peer struct for 182.93.2x.x, peer port 500
003607: ISAKMP: New peer created peer = 0x861289F4 peer_handle = 0x80000027
003608: ISAKMP: Locking peer struct 0x861289F4, refcount 1 for isakmp_initiator
003609: ISAKMP: local port 500, remote port 500
003610: ISAKMP: set new node 0 to QM_IDLE
003611: ISAKMP:(0):insert sa successfully sa = 8AAB28E0
003612: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
003613: ISAKMP:(0):found peer pre-shared key matching 182.93.2x.x
003614: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
003615: ISAKMP:(0): constructed NAT-T vendor-07 ID
003616: ISAKMP:(0): constructed NAT-T vendor-03 ID
003617: ISAKMP:(0): constructed NAT-T vendor-02 ID
003618: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
003619: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
003620: ISAKMP:(0): beginning Main Mode exchange
003621: ISAKMP:(0): sending packet to 182.93.2x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003622: ISAKMP:(0):Sending an IKE IPv4 Packet......
CPKZHCME#
003623: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003624: ISAKMP (0): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
003625: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003626: ISAKMP:(0): sending packet to 182.93.2x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003627: ISAKMP:(0):Sending an IKE IPv4 Packet.
003628: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003629: ISAKMP (0): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
003630: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003631: ISAKMP:(0): sending packet to 182.93.2x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003632: ISAKMP:(0):Sending an IKE IPv4 Packet.
003633: ISAKMP: set new node 0 to QM_IDLE
003634: ISAKMP:(0):SA is still budding. Attached new ipsec request to it. (local 183.63.x.x, remote 182.93.2x.x)
003635: ISAKMP: Error while processing SA request: Failed to initialize SA
003636: ISAKMP: Error while processing KMI message 0, error 2.
003637: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003638: ISAKMP (0): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
003639: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003640: ISAKMP:(0): sending packet to 182.93.2x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003641: ISAKMP:(0):Sending an IKE IPv4 Packet.
003642: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE...
003643: ISAKMP (0): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
003644: ISAKMP:(0): retransmitting phase 1 MM_NO_STATE
003645: ISAKMP:(0): sending packet to 182.93.2x.x my_port 500 peer_port 500 (I) MM_NO_STATE
003646: ISAKMP:(0):Sending an IKE IPv4 Packet.
6 Replies 6
Julio E. Moisa
Please check this link, apparently the lifetime assiociation could be the problem:
https://learningnetwork.cisco.com/thread/61216
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
post the configurations of both sides...
thanks for your reply, below configure for both side
router _A configure
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 5
 lifetime 3600
crypto isakmp policy 10
 hash md5
 lifetime 3600
crypto isakmp key KEY address 183.63.x.y
crypto isakmp keepalive 10 3
crypto isakmp nat keepalive 10
crypto ipsec security-association lifetime seconds 1800
crypto ipsec transform-set set-10 esp-3des esp-sha-hmac
crypto map to-central 10 ipsec-isakmp
 set peer 183.63.x.y
 set transform-set set-10
 match address mo-zh-acl
ip access-list extended mo-zh-acl
 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
interface FastEthernet0/0
 description $FW_OUTSIDE$
 ip address 182.93.2x.x 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 load-interval 30
 duplex auto
 speed auto
router_B configure
 encr 3des
 group 5
 lifetime 3600
 hash md5
 lifetime 3600
crypto isakmp key KEY address 182.93.x.x
 set peer 182.93.x.x
 match address zh-mo
ip access-list extended zh-mo
 permit ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
 ip address 183.63.x.y 255.255.255.252
 ip verify unicast reverse-path
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
Are both sites running this version of code?
Rick
Rick
yes both side have same version
Can you also show the loopback at each side and the routing for loopback and segment intended for the tunnel?
