Slow network response while accesing via MetroEthernet
enriquebs
HI all,
When we try to access a 2800 router via MetroEthernet we spend a lot of time until the username and password prompt appears, so... after it the router is working slowly, what I mean is that for example you can not write a command in a fluent way.
It seems a line (MetroEthernet) issue, but the ISP don't tell us any information. Is there any way to check it in the router? I've been trying with the show controllers command but this info is difficult to understand.
Any idea?
Thx a lot in advance.
cheers,
7 Replies 7
peterledwidge
Ensure you have the correct speed and duplex settings for optimal performance, sounds like there maybe a mis match issue.
clear counters ethernet/fastethernet x
sh int ethernet/fastethernet x
Check for errors or late collisions on the link.
Hope this helps.
Peter
HI Peter,
Here is the sh int output:
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0017.5abb.8ffe (bia 0017.5abb.8ffe)
Description: "X"
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 06:52:17
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3000 bits/sec, 5 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
93624 packets input, 6378502 bytes
Received 81579 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
14823 packets output, 1376643 bytes, 0 underruns
0 lost carrier, 0 no carrier
Counters looks fine, and the config is similar to other sites, Full-Duplex/10. No way to change to Full-Duplex/100 because of the device facing us. But this config works good in other remote sites.
Thx
wochanda
Level 4
Level 4
What do you mean "try to access a router via metroethernet"? You mean a remote telnet connection is slow?
How is the performance of the network behind the 2800? Are you able to push/pull files to hosts behind the router?
If so, it doesn't sound like a MetroE problem. Could be that your router is too busy doing other things to respond to your telnet. To check, try a 'show proc cpu history'.
Yes, it's an ssh session to a 2800 router via MetroLAN. I don't manage the LAN, so, I can't get access to any host.
Anyway, the router cpu never goes over 5%
thx
The slowness may be due to the default MTU setting. Equipment or links on the SP network may have a problem with an MTU 1500 + trunk overhead. Can you configure the command 'ip tcp adjust-mss 1400' on the interface facing the users (LAN) and see it that makes any difference.
Sundar
HI Sundar,
I wanna try it, but there is something that I don't understand... when you says "command 'ip tcp adjust-mss 1400' on the interface facing the users (LAN)" do you mean the interface on the 2800 router facing the MetroEthernet network? because the LAN addresses are not managed bu us...
thx
Actually, you can configure the command 'ip tcp adjust-mss 1400' on any interface in the path of the TCP traffic. What this does is the router transparently lowers the MTU to 1400 during the TCP session negotiation between the client and the server. I have had good success eliminating MTU problems when doing so.
Good Luck!!
Sundar
