SMARTnet Question
info
What is the difference between CON-SNT-3925CMST and CON-SNT-3925SEC? How do I know which one to get?
keglass
Level 7
Level 7
Anthony,
I found this ordering guide that might be helpful for you. Please refer to Table 25 and Table 28 for information on what is included in the different security bundles.
Cisco Integrated Services Routers Generation 2 Ordering Guide - Cisco
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
keglass
Level 7
Level 7
Anthony,
I hope this helps.
Kelli Glass
Kelli,
Thank you very much
