SNMP - ifAdminStatus - Up, Down, Testing
jjustice
Community Member
Trying to understand SNMP-ifAdminStatus level of 3, which is listed as 'testing'.  We are all familar with setting the admin status to either up or admin down with the the 'shut' or 'no shut' commands, but what is it that would list an SNMP ifAdminStatus of 'testing'?  Any help is appreciated
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ifAdminStatus#oidContent
ObjectifAdminStatus
OID1.3.6.1.2.1.2.2.1.7
TypeINTEGER
Permissionread-write
Statuscurrent
Values1 : up
2 : down
3 : testing
MIBIF-MIB ;   -   View Supporting Images this link will generate a new windowhttp://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ifAdminStatus
Description"The desired state of the interface. The testing(3) state
indicates that no operational packets can be passed. When a
managed system initializes, all interfaces start with
ifAdminStatus in the down(2) state. As a result of either
explicit management action or per configuration information
retained by the managed system, ifAdminStatus is then
changed to either the up(1) or testing(3) states (or remains
in the down(2) state)."
graham smart
Level 4
Level 4
I can only assume it goes into that state when a line card comes online and the ports are run though the inital testing/diags before coming online?
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
