SNMP Virtual-Access interface Traps
powertome1
Folks, can anyone help me with an issue whereby we are constantly receiving SNMP traps for virtual-access interfaces going up and down, what do we need to add to out config :
stschmidt
Can you add a "sh ver" to the post for me?
Stephen
Please see attached :
#sh ver
IOS (tm) 3600 Software (C3640-I-M), Version 11.3(10)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Wed 02-Jun-99 05:46 by pwade
Image text-base: 0x60008918, data-base: 0x605CA000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOIAS-NIA-3> uptime is 1 year, 40 weeks, 2 days, 2 hours, 11 minutes
System restarted by power-on at 10:26:43 GMT Mon Feb 21 2005
System image file is "flash:c3640-i-mz.113-10.T", booted via flash
cisco 3640 (R4700) processor (revision 0x00) with 36864K/12288K bytes of memory.
Processor board ID 15617739
R4700 processor, Implementation 33, Revision 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
32 Serial network interface(s)
1 ISDN Basic Rate interface(s)
1 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
