Socat unicast stream to multicast, then that data into cisco multicast
techteching8
Hi, i hope its right post location for this kind of problem.
I tried to send unicast data with PacketSender to Socat(Debian 12 Server), convert that to Multicast and send that data to Cisco multicast interface/group.
When i try do send Multicast data with MCastTest it will work, MCastTest receiver 1 and 2 will get the data.
When i try do send data with Socat over Cisco router, data don't go to MCastTest 1, it will go to MCastTest 2.
Unicast ping works all-around.
MCastTest - https://www.dqnetworks.ie/toolsinfo/mcasttest/
When i send data with MCastTest, it will go to McastTest receiver 1 and 2.
When i tried to send UDP data with PacketSender to Socat, convert it and send it to MCastTest 1 and 2. Only MCastTest 2 receives data.
I can see that Socat sends multicast out from e0 192.168.10.2 (Interface towards Cisco Router, Cisco R1 f0/0 192.168.10.254).
Test 1:
Multicast to McastTest Receiver 1
socat -d -d UDP4-RECV:8006, bind=192.168.10.2 UDP4-DATAGRAM:229.1.1.1:8002, bind=192.168.10.2,reuseaddr
Test 2:
Multicast to McastTest Receiver 2 works!
socat -d -d UDP4-RECV:8006, bind=192.168.10.2 UDP4-DATAGRAM:229.1.1.1:8002, bind=10.10.20.2,reuseaddr**
R1
ip multicast-routing
interface FastEthernet0/0
ip address 192.168.10.254 255.255.255.0
ip pim sparse-dense-mode
ip igmp join-group 229.1.1.1
duplex half
interface FastEthernet1/0
ip address 172.21.0.1 255.255.255.0
duplex auto
speed auto
ip mroute 10.10.10.0 255.255.255.0 172.21.0.2
ip route 10.10.10.0 255.255.255.0 172.21.0.2
R2
ip address 10.10.10.254 255.255.255.0
duplex half
ip address 172.21.0.2 255.255.255.0
duplex auto
speed auto
ip route 192.168.10.0 255.255.255.0 172.21.0.1
ip mroute 192.168.10.0 255.255.255.0 172.21.0.1
Harold Ritter
Hi @techteching8 ,
It might be due to the TTL value being used by socat by default. Try increasing it using the ip-multicast-ttl parameter.
Harold Ritter
Hi @techteching8 ,
