Software for Cisco 2811
Got a Cisco 2811 router from my school, which can be used as a terminal server, but my problem is that it has been wiped, so i don't have the IOS for it and it can't be downloaded anymore, does anybody have software for this router?
KR Christian Josiassen
 Do you have access to the router?
 I dont belive they wiped the IOS. Usualy they wipe the config. If you can access it, look in the flash: maybe you find an IOS there.
 For sure you can  not get one here as Cisco will not permit.
The flash is wiped, because it's blank when i do dir flash:
Joseph W. Doherty
Have you tried searching the Internet for such software?  E.g. like searching for
c2800nm-ipbasek9-mz.124-12.bin
