software for Tcp/udp/application protocol testing
tanszewee
i having some strange problem with my WAN from site A to B.
TCP protocol like http is working fine other like RPC is working very slowing or timeout .Is there any software that it can perform end to end testing to find out which protocol is not working throught the WAN and report to my WAN provider ?
pciaccio
Level 4
Level 4
You can try using IPerf. It is free and you can test TCP and UDP traffic. It will provide the results to you and you can send that to your provider....
