SOLVED : IP SLA do not work in Cisco ACI
vgr
Hello
I configured an IP SLA ICMP testing to check the availability of a directly connected neighbor.
The track_list is applied on a static default route on my leaves.
It seems the track_list is not tested : the static default route is avaliable even if the IP is not reachable.
Could you please help to solve the issue ?
Thanks in advance.
Vince
is the track list actually down ? Post the running configuration of your ACI...
The status is currently Timeout
Please find the configuration joined
Vince
how many IP SLAs do you have ?  You have made most of the information invisible. What is the track list, and where are you applying it ?
Hello.
Finaly all is working good with my configuration
Thanks again.
Vince
