Some theoretical issue
toruzzz
Hi TAC!
I have a little theoretical issue!
I already solved my problem, but I want to understand reason of this problem!
I have 2 router connected together through frame-relay link:
router A:
interface Serial0
ip address 10.20.30.1 255.255.255.0
encapsulation frame-relay
frame-relay interface-dlci 16
interface Ethernet0
ip address 172.16.34.66 255.255.255.0
router B:
interface serial0
ip address 10.20.30.2 255.255.255.252
frame-relay intf-type dce
But then I ping from B(10.20.30.2) to A(10.20.30.1) I see that some ICMP packets not returned - it's look like:
Sending 5000, 100-byte ICMP Echos to 10.20.30.1, timeout is 2 seconds:
Success rate is 98 percent (4910/5000), round-trip min/avg/max = 44/46/272 ms
As You can see - I have some appropriateness!
There are some sets of dots(".") - 30 pieces => 30 * 2 sec(timeout) = 60 sec
60 seconds I don't have ICMP pacets back, but after this 60 second time out I have again.
The problem was in the irregular netmask on Serial0 router A, after my changing from /24 to /30
I don't have any problems!
The question is - what kind of timers can do it(may be some frame-relay keepalive)?
TIA
Yev.
Hello Yev,
I have tried to reproduce your problem in a lab environment, but all my pings go through...
I am thinking that your provider is using a routing protocol that might get confused with your different networks. You could use a utility such as PINg Plotter (www.pingplotter.com) and check at which hop the packet loss occurs. The utility also shows you changes in the routing path between two hosts.
HTH,
GP
