10-05-2021 08:09 AM
Good day
There is a way to sort the output of the sh ip arp, for example, in descending order of ips addresses. My network is running Ios 12 ?
PD: I know that on IOS 15 and beyond i can use Linux commands to sort output, but i didnt find yet a way to sort the output of the sh ip arp command in order of ips addresses.
Solved! Go to Solution.
10-05-2021 08:14 AM
Hi there,
The only way to sort the output would be to process it off device. Regarding the linux guest shell, that is available on IOS-XE 16.x , but not IOS 15.x .
cheers,
Seb.
10-05-2021 08:14 AM
Hi there,
cheers,
Seb.
10-05-2021 08:28 AM
10-05-2021 08:28 AM
You already answered yourself,. out of the box Linux is good option and you make output what ever you like.
