Source NAT port range settings
Omars
Visitor
Hello all,
I would like to know what is the default port range of source NAT overload on a Cisco router ? <1024–65535> ?
So, this command  "ip nat settings interface-overload port range start <1024–65535>" allow me to limit or increase the default  range ?
Thank you !
Georg Pauwen
I don't think there is a default. The command:
show ip nat portblock dynamic global detail
tells you what is configured. Without you actually defining a range, the command should render no output/result, meaning that by default, no ports are blocked.
Georg Pauwen
Thank you Georg !
This command (show ip nat portblock dynamic global detail) show the TCP/UDP port blocks allocated for NAT.
