SPA-1XCHSTM1/OC3
clark white
Level 2
Level 2
Our ISP ordered SPA-1XCHSTM1/OC3 card from my company, for his plenty of customers. I want to know how i can configure the card, Can anybody route me to the configuration example for confguring the card. also it will be more clear view if anybody can share a topology showing how it is useful in ISP network.
clark white
Level 2
Level 2
Nobody has expierience with this card, I am waiting for the experts reply. Anybody can route me to configuration example.
Here you go : ASR config example
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/ASR1000/ASRcstm1.pdf
7600 series routers SPA configuration examples:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76pref.html
Good luck ... Rate helpfull posts please
Hello
I am configuring channelized E1 on 7600 according to the link below
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76cfstm1.html#wp1213528
On E1 Configuration (Channelized T3/E3 mode) section on the link i dont get the command specified in the link, i have only the below option.
Router(config-ctrlr-sts1)#?
Sonet/SDH Configuration Commands
  exit       Exit from Sonet/SDH Path configuration mode
  idle       Specify idle pattern for all channels in the path
  mode       Specify path operation mode
  no         Negate a command or set its defaults
  overhead   Configure sonet path overhead flags
  shutdown   Shut down the Sonet/SDH path
  threshold  Set Path BER threshold values
  vtg        vt-15 configuration
can anybody help me to configure the card professionally as such it is working live for somebody network.
