%SPA_CHOC_DSX-3-HDLC_CTRL_ERR issue
HCL Support
We have Cisco 7609 Router and SIP module at slot.
Now we are getting this error continue from yesterday asgivenbelow,
Also find attached show logging, show version, show module command output.
Regds,
Ashutosh
vmiller
Level 7
Level 7
here is the book answer:
Explanation    The SPA driver detected an error event on the HDLC Controller.
Recommended Action    The SPA driver has encountered an error event on the SPA card. If the condition  persists, copy the error message exactly as it appears. Next research and attempt to resolve the issue  using the SPA hardware troubleshooting documentation. Copy the message exactly as it appears on  the console or in the system log. Research and attempt to resolve the issue using the tools and  utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will  supply clarifying information. Search for resolved software issues using the Bug Toolkit at  http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance,  open a case with the Technical Assistance Center via the Internet at  http://tools.cisco.com/ServiceRequestTool/create, or contact your Cisco technical support  representative and provide the representative with the information that you have gathered.
Amit Aneja
Level 3
Level 3
The error is a parity error on the bus - most likely a hardware issue. there is an internal bug on this as well, I would suggest opening a case with TAC.
