Speedup failover switchover
richmorrow624
I have several remote sites that I want to set up in the
following way, I have it set up in a lab now:
The primary is connected via MPLS and is using OSPF for connectivity to the HQ
site.
The secondary has a VPN connection to the Internet as a failover connection.
Both connections are always up.
When the primary fails, it seems to take about two minutes before the switchover provides connectivity back via the VPN connection using RIP. When the
connection to the MPLS cloude is re-established, it takes about 3 minutes to
connect via OSPF.
Keep in mind this is a lab situation and has not been implemented just yet,the
configs are provided for the remote lab sites.
I would like the switch over to take only 10 seconds or so both ways, can this
be done?
If both connections are up all the time, it seems it should switch faster,
unless the routers have to let the routes die and repopulate with the other
protocol.
Would this be the reason it is taking so long?
Is this what I should expect as far as efficient failover?
What can I do to speed this up?
richmorrow624
forgot the configs
