SSH and zone-based firewall
Kris McCormick
From the outside, I am unable to SSH into a Cisco 2901 router with a zone-based firewall. I suspect I need to add SSH to one of the zones but I'm not sure which one. I've attached the configuration in a text file.
Thanks in advance to anyone that can point me in the right direction.
cadet alain
you want to ssh into the router from any outside IP or from a specific one ?
The problem is here:
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
policy-map type inspect ccp-permit
class type inspect ccp-cls-ccp-permit-1
  pass
class type inspect SDM_EASY_VPN_SERVER_PT
  pass
class type inspect SDM_EASY_VPN_CTCP_SERVER_PT
  inspect
class class-default
  drop
the ssh traffic is classified as class-default traffic and is dropped.
You may do this if you want any IP to ssh:
ip access-list extended SSH
  permit tcp any any eq ssh
class-map type inspect SSH_ACCESS
match access-group name SSH
class type inspect SSH_ACCESS
   inspect
If you want to permit only certain IPs then modify the ACL consequently
Regards.
Alain
cadet alain
  pass
  pass
  inspect
class class-default
  drop
   inspect
Regards.
Alain
Kris McCormick
Thanks Alain, I did want to enable ssh from any outside IP so this worked perfectly!
Somewhat off topic, do you know a good resource for learning more about zone-based firewalls?
Kris
Hi Kris,
Deploying Zone-Based Firewalls (Digital Short Cut) from Cisco Press
Regards.
Alain
