SSH Login
rkretzschmar
I have an ASA 5510 and when I go to test the SSH I am getting a password authentication failure. My password works with telnet and ADSM. I have tried the default login, I have tried to use the enable password and I have completely removed the password from one account I setup for testing and get the same issue. I also have tried to connect on 4 different PCs. Is there something that I am missing on the config?
stomasko
Level 4
Level 4
Without seeing your config a little hard to say. Try looking at the following site to make sure you've followed these steps:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml
Hope this helps.
Steve
rkretzschmar
Thank you for your help. They were the docs I was looking for to check my config. It is working now. I appreciate the help.
