SSH Pass-through AND SSH To Router
jwynacht
I've a question regarding SSH on my router. Right now I have things set up to do pass-through to a server I have on the inside of my network. However, I'd also like to be able to SSH to the router itself but it seems like after setting up pass-through I can't do that anymore. I'm sure there's a simple solution, like configuring a new interface but I'm not sure I understand what that solution is.
Any advice? Config below.
Thanks!
Jon
Current configuration : 2457 bytes
version 12.4
hostname ROUTER_HOSTNAME
boot-start-marker
boot-end-marker
no logging console
enable secret SOME_PASSWORD
enable password SOME_PASSWORD
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LANpool
import all
network 192.168.1.0 255.255.255.0
dns-server 68.94.156.1 68.94.157.1
default-router 192.168.1.254
lease infinite
ip cef
ip domain name DOMAIN.COM
ip name-server 68.94.156.1
ip name-server 68.94.157.1
ip port-map ssh port tcp 30000 list 10
ip ssh logging events
ip ssh version 2
vpdn enable
username USERNAME privilege 15 secret 5 SOME_PASSWORD
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
description Internet Connection
no ip address
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
speed auto
interface FastEthernet1
description Connection to Wireless LAN
switchport access vlan 26
interface FastEthernet2
description Connect to LAN
interface FastEthernet3
description Internal LAN Server
interface FastEthernet4
description Connection to DMZ
no cdp enable
interface Vlan1
no ip address
interface Vlan26
description routed interface for LAN segment
ip address 192.168.1.254 255.255.255.0
ip nat inside
interface Dialer1
mtu 1492
ip address IP_ADDRESS SUBNET
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname HOSTNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password 0 PASSWORD
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.60 22 interface Dialer1 30000
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit IP_ADDRESS 0.0.0.255
access-list 10 permit 192.168.1.60
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input ssh
end
John Blakley
I believe you can change your ssh port on the router like:
ip ssh port rotary 1
That might work.
HTH,
John
HTH, John *** Please rate all useful posts ***
Mmmm....didn't do anything here. Not sure if this clarifies things or not but I need to be able to do the following:
1. ssh directly to router.
2. ssh directly to server (via passthrough).
Wondering if I need to use PAT here?
TIA,
Jon
Or, do I configure a separate interface to ssh to the server and use the original interface to connect to the router?
