SSH to a host in a VRF
thomaslthorne
I have a 3825 running c3825-advipservicesk9-mz.124-13b.bin. I have multiple VRFs defined on it. Is there a way to ssh from the router to a host inside a VRF similar to:
telnet 192.168.1.5 /vrf word
9 Replies 9
Joe Clarke
As of 12.4(20)T, the ssh command supports a -vrf option. It has not been merged into other trains.
Would this be the correct syntax?
ssh -l user 192.168.1.5 -vrf
When I do this, it gives me the error:
% Destination unreachable; gateway or host down
However, I can ping inside the VRF and get a reply.
You're missing the actual VRF name. The syntax would be:
ssh -l user -vrf NAME 192.168.1.5
Where NAME is the name of the VRF.
I get the following error:
router#ssh -l user -vrf name 192.168.1.5
% Invalid input detected at '^' marker.
Unless you're running 12.4(20)T or higher, you don't have this command. I had assumed you upgraded, but if you're still on 12.4(13b), then you will not be able to use SSH with VRF support.
Thanks for heads up, I will give this a try in the lab. This will certainly help if I can make it work.
jclarke,
We're trying to do the same thing except with a 6509-E running 12.2(33)SXH4.  Is there an IOS for the 6509-E that will allow us to SSH through a VRF?
Jesse
I do not see a version of CatIOS which supports this command.  I only see that it was integrated into 12.4(20)T.
Ok, thanks.
