SSL VPN licences
skibo.networks
I want to buy Cisco 1941/K9 router and also need to configure SSL VPN/Cisco anyconnect. Also buying FL-SSLVPN10-K9 for SSL licenses, can someone please advise if I need 1941/K9 or 1941 SEC/K9 router?
Hasrat
Mark Malone
You want the sec/k9 basically means security image with k9 encryption ,that will work for ssl/IPsec vpns etc with the correct licenses
with just k9 it could come with advanced routing image capable of IPsec but better to have an advanced sec image on it for those type features
Mark Malone
Thanks Mark,
