Stacking a 3750?
WillaBamm
I have a 3750-48-TS-E and was thinking I would buy a matching PoE switch, but I can't seem to find one that is PoE that the MPN ends with an "E". Can I use StackWise on a 3750-48-TS-E & a 3750-48PS-S?
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes.  Generally you can stack any 3750 with any other, although there are considerations.  For example, the two IOS version don't need to match, but if they don't they need to have compatible stack versions.  Feature sets also don't need to match, such as in your question, but if the stack member's "smarter" member fails the remaining member loses features.
Disclaimer
Posting
During stack master elections, by default, member switches with a "better" feature set have preference over those that do not.
Joseph W. Doherty
Disclaimer
Posting
Thank you. I plan to update my 3750's IOS to the newest version anyways and if I get another switch, I will update it as well.
As for the ""smarter" member fails the remaining member loses features.", Would that mean I need to make the PoE switch the master and the non-PoE the slave?
Disclaimer
Posting
Thank you.
