05-11-2011 10:17 PM - edited 03-04-2019 12:22 PM
Hi Friends,
I have two numbers of c3750 x -48T-L switches and one C3750x-24P-L switch. I want to do stacking in between these switches. Kindly let me know the advantages of stacking and how can we do the stacking process. Also please let me know the commands which are using in the stacking process.
Ranji...
05-11-2011 10:19 PM
Yes you can stack them.
Simple rule of thumb:
1. Make sure the new switch has the the same IOS version and feature as the stack.
2. Before adding the new switch, use the "provision switch" command, make the necessary port configurations before proceeding.
3. During the addition of the switch to the stack, make sure you power the new switch OFF, connect the stack cable before applying power.
4. When the new switch has come up and is seen by the stack, then use the "switch
NOTE: Make sure you all members of the stack must have the same IOS version and feature set.
05-11-2011 10:39 PM
Hi leolaohoo,
Thank you so much for your quick reply.
Please let me know about the stacking process (How do we connect the cables, ports...) . Also how do I make the switches to maser and slave? Which topology is better to make stacking.?..advantages? Also how do I set priority?
Ranji
05-11-2011 10:56 PM
