Standalone switch with TACACS configuration
sanjaynadarajah
I have a used Cisco ASR and I cannot get into the switch. It looks to me that it either has a local username and password OR the configuration had TACACS on it.
I would like to know since its a now an offline, non-production router;  if it had tacacs configuration on the router, would the router still be prompting for  the TACACS credentials if we try consoling to the router ?
Please advise.
Thank you.
Cheers,
-Sanjay-
johnlloyd_13
Level 9
Level 9
hi,
is it for an ASR router or switch?
please post the sanitized config.
If it is offline, then the TACACS server not reachable so will use the local username and password
Hello
 no it wouldn't - Usually when AAA is configured with Tacacs it is wise to apply a alternative logon access in case the Tacacs server Is unreachable
Usually you would specify the devices local user database also
Personally when am I working remotely I apply a "backdoor" access in the form of a rotary vtty port- This gives me access even if Tacacs is enabled
When I am on site and have direct access to the console as an small interim security measure I apply a console command -  activation-character 64
This gives me a good measure of local security access without applying any global access control feature
res
Paul
Kind Regards
Paul
