Starlink on Cisco C921-4P
Nicolas74
Hi all,
Need some help to setup correctly my c921-4P to use Starlink as internet accès connected on my Wan Port.
I can't acces to Internet, Starling is on Bypass mode.
My conf. is:
interface GigabitEthernet0
switchport access vlan 3
switchport trunk native vlan 3
switchport mode trunk
no ip address
interface GigabitEthernet1
switchport access vlan 4
switchport trunk native vlan 4
no ip address
interface GigabitEthernet2
switchport access vlan 5
switchport trunk native vlan 5
no ip address
interface GigabitEthernet3
switchport access vlan 6
switchport trunk native vlan 6
no ip address
interface GigabitEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Vlan3
ip address 192.168.30.3 255.255.255.0
ip nat inside
interface Vlan4
ip address 192.168.40.3 255.255.255.0
ip nat inside
interface Vlan5
ip address 192.168.50.3 255.255.255.0
ip nat inside
interface Vlan6
ip address 192.168.60.3 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list SAEM interface GigabitEthernet4 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 dhcp
ip access-list standard SAEM
permit 192.168.50.0 0.0.0.255
control-plane
banner motd ^C****ACCES AU ROUTEUR STARLINK***^C
line con 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
Thanks a lot for your help
Nico
27 Replies 27
Mark Elsen
 - Perhaps some of these articles may provide hints : https://community.cisco.com/t5/routing/cisco-1841-and-starlink-need-help/td-p/4614683 and https://www.reddit.com/r/Starlink/comments/lbyusc/how_to_configure_starlink_and_cisco_rv325_dual/
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thks M.
But i've already consult these articles but no solution.
To complet my post:
I reach 8.8.8.8 or google.fr from C921P and my laptop but not internet
from Edge, Chrome (maybe no dns resolution or www acces).
 - Strange  , what error do you get in the browser(s) ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
no specific error just a "ERR_CONNECTION-CLOSED"
pieterh
where do you connect your laptop ?
-->> only vlan-5's addresses are selected for NAT to the internet
if you want internet for the other vlan's you need to include these for NAT
My Laptop is in Vlan Ip address 192.168.50.203
i 'm just testing on this Vlan5.
Regard,
so my suggestion was not helpfull,
you also tried multiple browsers: "from Edge, Chrome (maybe no dns resolution or www acces)."
so retrieve network settings and check DNS resolution
- on windows pc "ipconfig /all"
- on linux "ifconfig -a"
- (both) "nslookup maps.google.com"
np
Yes tried on mulitple browsers  and i confirm you there is no dns resolution.
Nslookup  google.com
Server; dns.google
Address: 8.8.8.8
Dns request  Time out
check with your ISP if they allow a third party DNS server! (google)
it may be they only allow their own DNS server(s) instead
I have not followed the entire thread, but try and add a DHCP pool to your router for Vlan 50, then set your clients to obtain their addresses through DHCP:
ip dhcp pool VLAN50
Network 192.168.50.0 255.255.255.0
default-router 192.168.50.3
dns-server 8.8.8.8
Hello Georg,
Thx for your help, i'm going to setup a dhcp pool on for Vlan50 and will come back with result.
Hi Georg,
Same problem in DHCP.
not good, obviously. Looking at the configuration of the switched ports, what is actually connected to these ports, since you configured them as trunks ? What if you just make them access ports ?
