Cisco 1841 and Starlink - need help
rspears1966
First I know the c1841 is 10/100 only.  Starlink has a GigE uplink, but still, will it work?
I'm not asking for a theoretical answer, I know theoretically it should work, I want to know will it work?
I have put this config (see below) on mine and tested the NAT, it works.  I see the router grab a Starlink CGNAT IPv4 address.  But it will not pass traffic.  I can ping the WAN interface Fast0/0 from inside the network, but I can not ping past.  Also, when I try to do a source ping (4.2.2.2) from the WAN interface, it fails to respond.  I can drop my Cradlepoint in place, and it works flawlessly, so I know it's not any of the cables or the Starlink equipment.
I am using c1841-advsecurityk9-mz.151-3.T2
Advise please.
c1841#
ip cef
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex full
speed 100
no cdp
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEtherner0/0 overload
ip access-list extended 100 permit any any
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
c1841#
the access list used for NAT does not look right. Make the changes marked in bold:
ip cef
ip address dhcp
ip nat outside
duplex full
speed 100
no cdp
ip nat inside
no ip http server
--> ip nat inside source list 1 interface FastEtherner0/0 overload
--> access-list 1 permit 192.168.0.0 0.0.0.255
--> ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
c1841
ip cef
ip address dhcp
ip nat outside
duplex full
speed 100
no cdp
ip nat inside
no ip http server
c1841
I will give this a try tonight, and update this thread.
Thanks in advance !!!
rspears1966
That did the trick.
Updating the config to reflect these changes worked.
Thank you
Wizard4777
if you are still using the starlink wifi router, you can just put default route as "ip route 0.0.0.0 0.0.0.0 192.168.1.1". If starlink router is in bypass mode, your default route should be "ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp"
