startup-config file open failed (Bad file number)
a.gooding
Level 5
Level 5
whats this all about. the router was working fine this morning. then my voice-cards stopped responding. we reloaded and thats the error i get everytime i attempt to save the config. when i reloaded the config was gone and gave the initial setup prompt.
any ideas?
2651XM - 12.4 10a
You may be having a corrupted NVRAM. Issue the command 'test memory' and check the status of NVRAM. If it failed the test, try write erase and if that doesn't help hardware replacement may be your only option.
Sundar
was thinking the same thing. fixed though, issued and erase startup and that fixed it. finally, something actually went easy huh..its so strange how things can go so horribly wrong sometimes....
thanks though
