Static IP
saquib.tandel
I have static IP on a DSL router and want to access 4 routers on the lan ( ssh or telnet )
For one router, I can do a static NAT but how can I access other 3 routers from Internet.
ST
Hitesh Vinzoda
Level 4
Level 4
You can do port forwarding based on the port numbers on the DSL router e.g.
Wan interface IP address port 3000     forward it to Router 1 ip address port 23
Wan interface IP address port 3001     forward it to Router 2 ip address port 23
Wan interface IP address port 3002     forward it to Router 3 ip address port 23
Wan interface IP address port 3003     forward it to Router 4 ip address port 23
so when you telnet wan interface ip address it will forward according to the port numbers where the telnet was received on the DSL router
telnet 1.2.3.4 3000 >> Goes to R1
telnet 1.2.3.4 3001 >> Goes to R2
and So on...
Hope this helps
Hitesh Vinzoda
Pls rate useful posts
Hitesh Vinzoda
Level 4
Level 4
and So on...
Hope this helps
Hitesh Vinzoda
