Static NAT support on sub interfaces
ckothako
Does the 3900 series router support static NAT on a sub interface ? I am trying to port forward RDP session from outside interface to the hosts on inside VLANs. Each VLAN is configured on a sub-interface as shown by the snippet below. Is this  a supported config ?
interface GigabitEthernet0/0
 ip address 172.16.16.41 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1.102
 encapsulation dot1Q 102
 ip address 192.168.2.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.103
 encapsulation dot1Q 103
 ip nat inside
 ip address 192.168.3.254 255.255.255.0
interface GigabitEthernet0/1.104
 encapsulation dot1Q 104
 ip nat inside
 ip address 192.168.4.254 255.255.255.0
thanks
Chandra
John Blakley
Yes, you can nat on subinterfaces with no issues...
HTH,
John
HTH, John *** Please rate all useful posts ***
