Static Nats with multihome environment
dan.goldberg
I am looking for examples or assistance on a Cisco 1811 please with static NATs.
I have three ISPs (T1, DSl1, and DSL2) and several statically NATted Web servers, and mail servers (each with a unique IP address). The problem is that traffic comes in on the link from the T1, for example, and can go back out on any of the three links. I want to reverse map the outbound traffic so that it goes back out on the same link *and address* it came in on since there are several virtual IP addresses involved.
I am not sure route maps will work since the do not specify the source address used in the return packet, or can they?
Any ideas? thanks!
Dan
Hello Dan,
you might want to look into adding route maps to your static NAT entries for your web and email servers as following:
ip nat inside source static 10.10.10.1 212.136.1.1 route-map TO_ISP_1
ip nat inside source static 10.10.10.2 212.136.2.1 route-map TO_ISP_2
ip nat inside source static 10.10.10.3 212.136.3.1 route-map TO_ISP_3
access-list 101 permit ip 10.10.10.0 0.0.0.255 212.136.1.0 0.0.0.255.
access-list 102 permit ip 10.10.10.0 0.0.0.255 212.136.2.0 0.0.0.255
access-list 103 permit ip 10.10.10.0 0.0.0.255 212.136.3.0 0.0.0.255
route-map TO_ISP_1 permit 10
match ip address 101
set ip next-hop X.X.X.X (next hop for ISP 1)
route-map TO_ISP_2 permit 10
match ip address 102
set ip next-hop Y.Y.Y.Y (next hop for ISP 2)
route-map TO_ISP_3 permit 10
match ip address 103
set ip next-hop Z.Z.Z.Z (next hop for ISP 3)
interface Serial1/0
description T1 Link To ISP_1
ip address X.X.X.X A.A.A.A
ip nat outside
interface ATM0/1
description DSL Link To ISP_2
ip address Y.Y.Y.Y B.B.B.B
ip nat outside
interface ATM1/0
description DSL Link To ISP_3
ip address Z.Z.Z.Z C.C.C.C
ip nat outside
interface FastEthernet0/1
ip address 10.10.10.254 255.255.255.0
ip nat inside
Obviously the IP addresses used are likely not yours, but you get the concept.
Can you try this and see if it works ?
GP
