Static Route Load Balance and Failover
mustafa.chapal
We have a Cisco 3925e router and we have two different ISPs connected. We have three WAN links from which ISP1 has a primary and backup link and ISP2 has just one primary link.
We load balance traffic between ISP1 and ISP2 and we want to configure failover if ISP1 primary link goes down and ISP2 link should work regardless. When ISP1 primary link goes down, the ISP1 backup link default route does not get injected in the routing table.
Please help us resolve this issue.
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 ip sla 3 reachability
interface GigabitEthernet0/0 (ISP1 Primary Link)
 ip address 1.1.1.2 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip virtual-reassembly in
 ip verify unicast reverse-path
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface GigabitEthernet0/1 (ISP1 Backup Link)
 ip address 2.2.2.2 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface GigabitEthernet0/2 (ISP2 Primary Link)
 ip address 3.3.3.2 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface GigabitEthernet0/3
 ip address 192.168.0.1 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 load-interval 30
 duplex auto
 speed auto
 no cdp enable
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 1
ip route 0.0.0.0 0.0.0.0 3.3.3.1 track 3
ip route 0.0.0.0 0.0.0.0 2.2.2.1 10
ip sla 1
 icmp-echo 1.1.1.1 source-interface GigabitEthernet0/0
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 2.2.2.1 source-interface GigabitEthernet0/1
ip sla schedule 2 life forever start-time now
ip sla 3
 icmp-echo 3.3.3.1 source-interface GigabitEthernet0/2
ip sla schedule 3 life forever start-time now
Julio E. Moisa
You could use an script (or many scripts) and adjust it to your requirements, the following script is just and example:
*If an response is not received from a specific destination, a script will be triggered automatically, removing the primary default route. I usually create an static routing pointing to the primary ISP  and to a public IP as my destination for the SLA.
Example: ip route 8.8.8.8 255.255.255.255 1.1.1.1  (primary ISP)
track 10 ip sla 10 reachability
delay down 10
ip sla 10
icmp-echo 8.8.8.8 source-ip 10.0.1.1
timeout 10000
frequency 15
ip sla schedule 10 life forever start-time now
ip sla enable reaction-alerts
event manager applet FAILOVER-INTERNET
 event tag prim syslog occurs 1 pattern "%TRACKING-5-STATE: 10 rtr 10 state Up->Down"
 event tag sec syslog occurs 1 pattern "%TRACKING-5-STATE: 10 rtr 10 reachability Up->Down"
 trigger
  correlate event prim or event sec
 action 1.0 cli command "enable"
 action 2.0 cli command "no ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 10"  <--remove the current default route.
 action 3.0 cli command "ip route 0.0.0.0 0.0.0.0 2.2.2.2 10"   <--create a new default route pointing to other next hop
 action 4.0 cli command "exit"
 action 5.0 cli command "write memory"
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
delay down 10
ip sla 10
timeout 10000
frequency 15
 trigger
Hope it is useful
