Static routing in main router
faniAhmed
I am trying to do static routing along with RIP. There are 3 routers that use RIP and are connected to main router (where I am trying to do Static routing). I am new to cisco packet tracer and do not have networks knowledge. If any one can help me that would be great. Thanks for any help.
I have attached the pkt file. The main router also has another network connected that has servers in it.
No one anymore use RIP use ospf or eigrp. Dont waste your time with this protocol.
I am a beginner and it is must to use static and RIP for my project. I will though have a look at what you told. Thanks for sharing
Hello @faniAhmed
 Take a look on the file I am attaching.
You can see that the advantage of a dynamic routing protocol is that it is easier to deploy (less work to do) and easier to maintain.
The network 192.168.(1/2/3).0 are working from the 193.168.1.0 network. But the 194 (right most) and the 10 (server one) are not working. I removed the RIP from the pkt you provided because I can not use RIP in the main router. It is though working with the RIP
