Static Routing with OSPF
parkbamjang
Hi!
Here's my topology:
It's a assignment given by my network teacher, but I'm having a problem.
The goal is to successfully
ping Router#0
from the PC, but the current
ping to Router#1
has also failed.
What should I do?
Here's configuration of R#1, R#3, L3#0.
R#1
ip route 0.0.0.0 0.0.0.0 10.10.10.1 (left interface of R#0)
ip route 0.0.0.0 0.0.0.0 20.20.20.2 100 (Backup route, it's R#2's left interface)
Router ospf 1
Router-id 1.1.1.1
Network 20.20.20.0 0.0.0.3 area 0
Network 20.20.20.4 0.0.0.3 area 0
Default-information originate
R#3
Ip route 0.0.0.0 0.0.0.0 30.30.30.4 (VLAN 10's SVI on L3#0)
Ip route 0.0.0.0 0.0.0.0 20.20.20.14 100
Router ospf 1
Router-id 3.3.3.3
Network 20.20.20.4 0.0.0.3 area 0 (between R#1~R#3)
Network 20.20.20.12 0.0.0.3 area 0 (between R#3~R#4)
L3#0
Vlan 10
Name VLAN10
Vlan 20
Name VLAN20
Vlan 30
Name VLAN30
Interface
gigabitethernet1/0
(connected with PC#1)
Switchport mode access
Switchport access vlan 20
Interface
gigabitethernet1/1
(connected with PC#2)
Switchport access vlan 30
Interface
gigabitethernet0/0
(left)
Switchport access vlan 10
Interface
gigabitethernet0/1
(right)
exit
Ip routing
Interface vlan 10
Ip address 30.30.30.4 255.255.255.240
No shutdown
Interface vlan 20
Ip address 30.30.30.17 255.255.255.240
No shutdown
Interface vlan 30
Ip address 30.30.30.33 255.255.255.240
No shutdown
Exit
Ip route 0.0.0.0 0.0.0.0 30.30.30.1 (Virtual router's ip in VRRP in R#3 and R#4)
PC's gateway is 30.30.30.4, which is VLAN 10's svi on L3#0.
if you want full configuration, check the attached work file.
help me....
 You are mssing configuration in R2.
Either you add ospf in R2 or you add two default route with different weight
ip route 0.0.0.0 0.0.0 > R1
ip route 0.0.0.0 0.0.0 > R2  2
R1, remove the default routes.
no ip route 0.0.0.0 0.0.0.0 10.10.10.1
no ip route 0.0.0.0 0.0.0.0 20.20.20.2 100
Remove default-information originate
Router ospf 1
Router-id 1.1.1.1
no default-information originate
R3: Remove the default routes
no ip route 0.0.0.0 0.0.0.0 30.30.30.4
no ip route 0.0.0.0 0.0.0.0 20.20.20.14 100
Add a static route in R3
ip route 30.30.30.0 255.255.255.0  30.30.30.4
Redistribut static on R3. Remove default-information originate
Router ospf 1
Router-id 3.3.3.3
redistribute static subnets
Router ospf 1
Router-id 1.1.1.1
Router ospf 1
Router-id 3.3.3.3
Thank you very much!!!
No sure where you are simulating this but I created the network on PacketTracer and it is working  fine.
I will add here in case you want to see.
