ISR4461 Bootloop
AhoySoy44
Community Member
We have an ISR4461 running on 16.12.08 (Gibraltar) we which are trying to move to 17.6.5 (Bengaluru). Once the IOS is transferred to the router and verified, we try and boot it, and the router gets stuck in a boot loop displaying the error 'Last reset cause: Unrecoverable Error'.
ROM is 16.12(2r)
In the rommon we can see the IOS file is available, however when we try and boot from that file the rommon complains it cannot find a bootable image
rommon 10 > dir bootflash:
0 0 drw- tracelogs
0 0 drw- sysboot
0 802196094 -rw- isr4400v2-universalk9.17.06.05.SPA.bin
0 0 drw- .dbpersist
0 0 drw- .installer
0 0 drw- core
0 0 drw- .prst_sync
0 0 drw- .rollback_timer
0 0 drw- gs_script
0 132108 -rw- memleak.tcl
0 0 drw- virtual-instance
0 0 drw- vman_fdb
0 0 drw- onep
0 0 drw- license_evlog
0 30 -rw- throughput_monitor_params
0 35 -rw- pnp-tech-time
0 156961 -rw- pnp-tech-discovery-summary
0 0 drw- lost+found
0 7805900 -rw- isr4400v2_rommon_1612_2r_SPA.pkg
0 649526896 -rw- isr4400v2-universalk9.16.12.07.SPA.bin
0 649802972 -rw- isr4400v2-universalk9.16.12.08.SPA.bin
rommon 18 > boot
Located isr4400v2-universalk9.17.06.05.SPA.bin
Failed to find bootable image on device bootflash:
We have redownloaded the file and tried again with no differing results. The file has worked on 3 of our other ISR4461s with the same process. We can boot 16.12.08 from Rommon with no problems.
ISR4461_4#sh run | i boot
boot-start-marker
boot system flash bootflash:isr4400v2-universalk9.17.06.05.SPA.bin
boot-end-marker
diagnostic bootup level minimal
Console from the bootloop (I have removed some of the #'s to fit in the page):
Package header rev 3 structure detected
IsoSize = 768192512
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 26CC468D:5AF85F9D:71704E94:CB25ABDA:FF2128DE
expected 26CC468D:5AF85F9D:71704E94:CB25ABDA:FF2128DE
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM1
ISR4461/K9 platform with 8388608 Kbytes of main memory
History
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
IsoSize = 768192512
Image validated
7 Replies 7
Leo Laohoo
In ROMMON, post the complete output to the command "set".
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
AhoySoy44
Community Member
rommon 2 > set
PS1=rommon ! >
LICENSE_BOOT_LEVEL=
MCP_STARTUP_TRACEFLAGS=00000000:00000000
INTF_MODE=
TFTP_RETRY_COUNT=20
THRPUT=boost
BSI=0
RANDOM_NUM=834219285
BOOT=bootflash:isr4400v2-universalk9.17.06.05.SPA.bin,1;
RET_2_RTS=10:43:38 UTC Tue May 30 2023
RET_2_RCALTS=1685443418
Going through the link you have sent, thanks for sending that over, it looks the business
What is the serial number of the router?
I think this is CSCur77024.
AhoySoy44
Community Member
Serial number is FDO2442M0NK, which I believe means it was manufactured in 2020
AhoySoy44
Community Member
To add to this, booting from USB stick also produced the exact same result as booting from the bootflash
RMA the router.
AhoySoy44
Community Member
Thanks for the help
