11-30-2009 03:26 PM - edited 03-04-2019 06:50 AM
I will be adding a 2nd ISP as a failover to an establshed config. Current setup uses BGP but I am NOT getting default 0.0.0.0 from the provider. I use static ip route 0.0.0.0 ... to get the traffic out. The failover provider IS going to send me 0.0.0.0/0. Question is will the static prevail over the BGP learned route or will I need to modify AD on static or weight the new neighbor? (Or in it's base form, which is preferred, static or BGP?)(Or, how do you equate AD which prefers lower # to weight which prefers higher #?!)
I had originally thought about filtering out the default and using IP SLA, but would like to keep it simple if possible. I could also try to get ISP 1 to send default, but he's one of the big boys and I'd like to get this done in the next few days.
Solved! Go to Solution.
11-30-2009 03:31 PM
The static route you have configured will take precedence because it will have the lowest AD, which sounds like what you want.
Jon
11-30-2009 03:31 PM
Jon
