Strange Message
rsoave
Hi , I have a 7204VXR (NPE400) with 10 ATM interfaces (PA-A3-8T1IMA) and 2 Channelized T1/PRI ports, and I am experiencing a message when the router is booted or not.
The message is: loki_cstate called for non-loki idb.
Have someonde seen this message some time?
Tks
thisisshanky
Level 11
Level 11
Is this a syslog message, can you paste the exact message in full.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Harold Ritter
It seems like you are running into CSCin72245, which is just a cosmetic bug. What version of code are you running? This bug is fixed in 12.3(12), 12.3(12)T and 12.2(25)S.
Let me know if I answered your question,
HI,
Tks for reply.
I am running version 12.3(8)T8, Enterprise.
c7200-js-mz.123-8.T8.bin
Rgds
As I said, it is really just a cosmetic bug and doesn't affect at all the operability or performance of the router. If you really want to get rid of it though, you would need to go to a minimum of 12.3(12)T.
