Strange routing
Hello dear community!
I have 3825 with IOS version c3825-adventerprisek9_ivs-mz.151-4.M6.bin.
My ISP give me tagged Ethernet link with 3 Vlan ID and 3 static ip-addresses. It was created 3 pppoe-client on my router.
When I ping from Internet one of my static IP-address I don't get a response. I see these in terminal:
May  7 18:47:02.993: IP: s=A.A.83.246 (local), d=B.B.117.177, len 60, local feature
May  7 18:47:02.993:     ICMP type=0, code=0, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
May  7 18:47:02.993: FIBipv4-packet-proc: route packet from (local) src A.A.83.246 dst B.B.117.177
May  7 18:47:02.993: FIBfwd-proc: Default:0.0.0.0/0 process level forwarding
May  7 18:47:02.993: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
May  7 18:47:02.997: FIBfwd-proc: try path 0 (of 1) v4-rcrsv-X.X.160.239 first short ext 0(-1)
May  7 18:47:02.997: FIBfwd-proc: v4-rcrsv-X.X.160.239 valid
May  7 18:47:02.997: FIBfwd-proc: ip_pak_table 0 ip_nh_table 0 if none nh X.X.160.239 deag 0 chg_if 0 via fib 69A199EC path type recursive
May  7 18:47:02.997: FIBfwd-proc: depth 1 first_idx 0 paths 3 long 0(0)
May  7 18:47:02.997: FIBfwd-proc: try path 0 (of 3) v4-ah-X.X.
C3825#unde all160.239-Di14 first short ext 0(-1)
May  7 18:47:02.997: FIBfwd-proc: v4-ah-X.X.160.239-Di14 valid
May  7 18:47:02.997: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Dialer14 nh X.X.160.239 deag 0 chg_if 0 via fib 0 path type attached host
May  7 18:47:02.997: FIBfwd-proc: packet routed to Dialer14 X.X.160.239(0)
May  7 18:47:02.997: FIBipv4-packet-proc: packet routing succeeded
May  7 18:47:02.997: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Dialer14 nh X.X.160.239 uhp 1 deag 0 ttlexp 0
May  7 18:47:02.997: FIBfwd-proc: sending link IP ip_pak_table 0 ip_nh_table 65535 if Dialer14 nh X.X.160.239 uhp 1 deag 0 chgif 0 ttlexp 0 rec 0
May  7 18:47:02.997: IP: s=A.A.83.246 (local), d=B.B.117.177 (Dialer14), len 60, sending
May  7 18:47:02.997:     ICMP type=0, code=0
May  7 18:47:02.997: IP: s=A.A.83.246 (local), d=B.B.117.177 (Dialer14), len 60, output feature
May  7 18:47:02.997:     ICMP type=0, code=0, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Ping comes into Dialer12 and response routed to Dialer14. Why? How I can solve it?
My routing table:
C3825#sh ip route
Gateway of last resort is X.X.160.239 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via X.X.160.239
      A.0.0.0/32 is subnetted, 3 subnets
C        A.A.81.249 is directly connected, Dialer16
C        A.A.83.202 is directly connected, Dialer14
C        A.A.83.246 is directly connected, Dialer12
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, Vlan1
L        192.168.10.162/32 is directly connected, Vlan1
      192.168.17.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.17.0/24 is directly connected, Vlan17
L        192.168.17.1/32 is directly connected, Vlan17
      X.X.160.0/32 is subnetted, 1 subnets
C        X.X.160.239 is directly connected, Dialer16
C3825#sh ip ro X.X.160.239
Routing entry for X.X.160.239/32
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
    directly connected, via Dialer16
      Route metric is 0, traffic share count is 1
    directly connected, via Dialer14
* directly connected, via Dialer12
And my ip interfaces:
C3825(config)#do s
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         unassigned      YES NVRAM  up                    up
GigabitEthernet0/0.12      unassigned      YES unset  up                    up
GigabitEthernet0/0.14      unassigned      YES unset  up                    up
GigabitEthernet0/0.16      unassigned      YES unset  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
FastEthernet0/0/0          unassigned      YES unset  up                    up
Dialer12                   A.A.83.246   YES IPCP   up                    up
Dialer14                   A.A.83.202  YES IPCP   up                    up
Dialer16                   A.A.81.249   YES IPCP   up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Access2            A.A.83.246   YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Virtual-Access4            unassigned      YES unset  up                    up
Virtual-Access5            unassigned      YES unset  up                    up
Virtual-Access6            unassigned      YES unset  up                    up
Virtual-Template1          A.A.83.246   YES unset  down                  down
Vlan1                      192.168.10.162  YES NVRAM  up                    up
Vlan17                     192.168.17.1    YES NVRAM  up                    up
9 Replies 9
antonio.guirado
Level 3
Level 3
This is is not strange. It only balancing.
Does ping work from your router?.
Are you using NAT in the Dialer interfaces?.
Does your ISP and your router support Multilink PPP?. Try to bundle all links in a only logical PPP link.
How to disable this load balancing?
C3825#ping 8.8.8.8 so di 12
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of A.A.83.246
Success rate is 0 percent (0/5)
C3825#ping 8.8.8.8 so di 14
Packet sent with a source address of A.A.83.202
C3825#ping 8.8.8.8 so di 16
Packet sent with a source address of A.A.81.249
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/28/28 ms
I'm using NAT with PBR to route inside networks through Dialer 14 & Dialer16 interfaces. Mail server must be available throgh Dialer 16. Anyconnect must be available through Dialer12
My ISP not support Multilink PPP.
I suppose link bundling is not proper solution in my case. Correct me if I'm wrong.
I think you must contact your ISP. Ping must work. Check one by one your connection (doing a shutdow in the dialer interface) to check that each one works. I think in not a balancing problem. It is a connectivy problem.
Regards.
C3825(config)#int di 14
C3825(config-if)#sh
C3825(config-if)#
May  8 11:44:06.544: %DIALER-6-UNBIND: Interface Vi5 unbound from profile Di14
May  8 11:44:06.544: Di14 DDR: dialer shutdown complete
May  8 11:44:06.548: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to down
C3825(config-if)#
May  8 11:44:06.552: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access5, changed state to down
C3825(config-if)#
May  8 11:44:08.544: %LINK-5-CHANGED: Interface Dialer14, changed state to administratively down
C3825(config-if)#do ping 8.8.8.8 so di
% Ambiguous command:  "do ping 8.8.8.8 so di"
C3825(config-if)#do ping 8.8.8.8 so dialer12
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/30/32 ms
C3825(config-if)#do ping 8.8.8.8 so dialer16
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/29/32 ms
C3825(config-if)#do sh ip route
May  8 11:44:28.656: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to up
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is B.B.160.239 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via B.B.160.239
      A.0.0.0/32 is subnetted, 2 subnets
      B.B.160.0/32 is subnetted, 1 subnets
C        B.B.160.239 is directly connected, Dialer16
C3825(config-if)#do sh ip route B.B.160.239
Routing entry for B.B.160.239/32
* directly connected, via Dialer16
C3825(config-if)#
When I shutdown Dialer14 I can ping 8.8.8.8 through Dialer12 and through Dialer16. When I do "no shutdown" in interface Dialer14 configuration mode there's no ICMP reply from 8.8.8.8 to Dialer 12 and to Dialer 14, but Dialer 16 receive ICMP reply.
How to disable load balancing through multiple Dialers?
I still think that is a routing problem not balancing. If you are using PBR you select (in the PBR) the next-hop
and if you are using NAT you select the return path because the IP address is only seen through one path. So
there is something else.
Try:
ping to x.160.239 from each dialer
shutdown dial12 and 16 and try icmp to 8.8.8.8 from Dialer14
one question. The connections are independent?. Each ip address x.83.246, x.83.202 and x.81.249 are supposed
to be associated to a different pppoe session?.
Yes, connections are independent and each ip address is assigned on specified PPPoE session. I have one default route x.x.160.239 accessible through 3 Dialer interfaces with the same metric.
Current configuration : 10628 bytes
dot11 syslog
ip source-route
ip cef
ip name-server B.B.160.50
ip name-server B.B.160.65
no ipv6 cef
redundancy
no ip ftp passive
ip ssh version 1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key *** address *.*.*.*
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map ZYWALL_VPN 1 ipsec-isakmp
set peer *.*.*.*
set transform-set ESP-3DES-SHA
match address 105
interface GigabitEthernet0/0
description FIBER_WAN
no ip address
duplex auto
speed auto
media-type rj45
no cdp enable
interface GigabitEthernet0/0.12
encapsulation dot1Q 12
pppoe enable group global
pppoe-client dial-pool-number 12
interface GigabitEthernet0/0.14
encapsulation dot1Q 14
pppoe-client dial-pool-number 14
interface GigabitEthernet0/0.16
encapsulation dot1Q 16
pppoe-client dial-pool-number 16
interface FastEthernet0/0/0
description LAN VLP
switchport mode trunk
no ip address
spanning-tree portfast
interface Virtual-Template1
ip unnumbered Dialer12
interface Vlan1
ip address 192.168.10.162 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip policy route-map USER_INTERNET
interface Vlan17
ip address 192.168.17.1 255.255.255.0
ip nat inside
ip policy route-map VOICE_INTERNET
interface Dialer12
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 12
dialer-group 12
ppp authentication chap callin
ppp chap hostname 111
ppp chap password 7 xxx
ppp ipcp dns accept
no cdp enable
interface Dialer14
mtu 1492
ip nat outside
encapsulation ppp
shutdown
dialer pool 14
dialer-group 14
ppp chap hostname 222
ppp ipcp dns accept
interface Dialer16
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 16
dialer-group 16
ppp chap hostname 333
ppp ipcp dns accept
ip local pool ANYCONNECT_POOL 192.168.11.1 192.168.11.254
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:ccmegui
ip dns server
ip nat inside source list NAT interface Dialer14 overload
ip nat inside source list NAT_2 interface Dialer16 overload
ip route 0.0.0.0 0.0.0.0 B.B.160.239
ip access-list extended NAT
deny   ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
deny   ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.10.0 0.0.0.255 any
ip access-list extended NAT_2
permit ip 192.168.17.0 0.0.0.255 any
ip access-list extended VPN
permit ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255 log
permit ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255 log
access-list 1 permit 192.168.11.0 0.0.0.255 log
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 2 permit A.A.83.246
access-list 105 permit ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 105 remark SITE-2-SITE ACL
access-list 2000 permit ip host A.A.83.246 host X.X.117.177
access-list 2000 permit ip host A.A.83.202 host X.X.117.177
access-list 2000 permit ip host A.A.81.249 host X.X.117.177
route-map VOICE_INTERNET permit 10
match ip address NAT_2
set default interface Dialer16
route-map USER_INTERNET permit 4
match ip address VPN
set default interface Dialer12
route-map USER_INTERNET permit 5
match ip address 1
set default interface Dialer14
control-plane
webvpn gateway SSL_GATEWAY
ip address A.A.83.246 port 443
http-redirect port 80
ssl trustpoint TP-self-signed-3690820435
inservice
webvpn install svc flash:/webvpn/anyconnect-win-3.1.02040-k9.pkg sequence 1
webvpn context ANYCONNECT_SERVIC
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group policy_1
   functions svc-enabled
   timeout idle 300
   svc address-pool "ANYCONNECT_POOL" netmask 255.255.255.0
   svc keep-client-installed
   svc split include 192.168.17.0 255.255.255.0
   svc split include acl 1
virtual-template 1
default-group-policy policy_1
aaa authentication list ciscocp_vpn_xauth_ml_1
gateway SSL_GATEWAY
inservice
end
All interfaces are UP:
ping B.B.160.239 so di 12
ping B.B.160.239 so di 14
ping B.B.160.239 so di 16
C3825#s
FastEthernet0/0/1          unassigned      YES unset  up                    down
FastEthernet0/0/2          unassigned      YES unset  up                    down
FastEthernet0/0/3          unassigned      YES unset  up                    down
C3825#ping B.B.160.239 so di 14
Sending 5, 100-byte ICMP Echos to B.B.160.239, timeout is 2 seconds:
Success rate is 0 percent (0/4)
C3825#ping B.B.160.239 so di 12
C3825#ping B.B.160.239 so di 16
C3825#
Interface Dialer12 & Dialer16 are DOWN:
C3825#s
Dialer12                   unassigned      YES IPCP   administratively down down
Dialer16                   unassigned      YES IPCP   administratively down down
Virtual-Access2            unassigned      NO  unset  up                    up
Virtual-Access4            unassigned      YES unset  down                  down
Virtual-Access6            unassigned      YES unset  down                  down
Virtual-Template1          unassigned      NO  unset  down                  down
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
C3825#
Hello Alexandr,
I have studied you configuration and all posts. Finally, I think you are rigth. The root cause for ICMP traffic genereated from your router does not work fine is balancing. Router receives ICMP Request in on dialer and the ICMP Reply goes back in other Dialer. You ISP applies anti-spoofing filters and drops the packet. Notice that this is only for traffic generated for the router.
You can play with administrative distances in static routes. For example, if you want for local traffic only used
Dialer 14 you can use:
no ip route 0.0.0.0 0.0.0.0 B.B.160.239
ip route 0.0.0.0 0.0.0.0 Dialer 12 100
ip route 0.0.0.0 0.0.0.0 Dialer 14 50
ip route 0.0.0.0 0.0.0.0 Dialer 16 150
If Dialer 12 is only for a site-to-site VPN you can route only the remote ip address:
ip route VPN-peer-address 255.255.255.255 Dialer 12
Traffic coming from ethernets interfaces is applied a PBR and forced to go through a dialer. In this case, NAT
translates the source inside address and the reply packet should come in the right dialer. Do you have any issues
with users traffic?. Is it right?.
Hello Antonio,
"100", "50" and "150" in these strings are not administrative distance. This is metric's value. I tried to change metric from default and 2 vlans goes to Internet through different Dialer interface in case of Dialer14 and Dialer16 are "up" and in the same time Dialer 12 is down.But ICMP-reply still not returned.
I want to have some public servers (mail-server, and Surveillance) available from Internet through different Dialer interfaces and session started from Internet will not return (like ICMP-request). In my opinion, construction with different metrics is not proper solution. Now I'm trying to split my router using VRF technology. In theory VRF may help.
Sorry for my terrible English.
Hello Alexandr,
review ip route command because is administrative distance and not metric. Perhaps the name "distance metric"
is a little confusing in the ip route command but its value it in the range 1-255.
At the end, I can know the real problem. You need access from internet to your servers that have private address,
don't you?. VRF Lite can let you use different routing table and its a very powerful feature. Notice that the routing
tables are differents, so if you want routing between them you must configure it with static routes from one VRF to other.
But I think it is not your problem. The problem is that you must to configure inverse NAT to map the public address to the server private address. For example, to map to a mail server:
ip nat inside source static tcp 25 25 extendable
Be careful that others NAT command (with the overload keywords) does not include the private_address.
Good luck!!
