Strange show version status on Cisco C6509 device
dae0712
I have a question because the value displayed in show version after firmware update is different from the existing value.
This is the equipment in question.
C6509-E, Catalyst 6500 Series Supervisor Engine 2T (IOS version: s2t54-adventerprisek9-mz.SPA.155-1.SY14.bin)
I transferred the file via TFTP and verified its integrity using the verify /md5 command, then changed the boot path and rebooted.
However, there are two supervisor modules, but when I put the file in only one bootdisk and rebooted, standby sup became cold.
Afterwards, the same file was sent to standby sup, its integrity was verified using the verify /md5 command, and it rebooted to return to the standby hot state.
The curious thing here is that when I originally checked the show version on the device, there was something different from before.
Example
Before change : s6t64 Software (s6t64-IPSERVICESK9-M), Version 15.3(1)SY2, RELEASE SOFTWARE (fc2)
After change : s6t64 Software (s6t64-IPSERVICESK9-M), Version 15.3(1)SY2, none
As in the example, can you tell me why none is floating where RELEASE SOFTWARE (fc2) should be?
I'm also curious about how to solve it and whether there are any functional issues.
Any help would be greatly appreciated.
Leo Laohoo
Console into the secondary supervisor card and reboot.
Post the entire boot-up process.
This is an environment where boot logs cannot be retrieved due to circumstances.
Then raise a TAC Case.
