Sub interfaces ACL
am.steen
I have a server at 10.30.2.200 on vlan2 which access internet on 10.30.2.252 but
1. I need to block it from access local network 10.30.2.0 only internet.
2. Also I need to access this server from my pc at 10.30.7.250 on vlan7
I am not good in cisco ACL so Please help
My router is 1941 and my setting is :
redundancy
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description *** WAN-Interface-WLPTP
ip address x.x.x.x 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex full
speed auto
interface wlan-ap0
ip unnumbered BVI1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
ip nat inside
no ip virtual-reassembly in
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/1.2
description Vlan Wserver
encapsulation dot1Q 2
ip address 10.30.2.252 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.7
description Vlan Managment
encapsulation dot1Q 7
ip address 10.30.7.225 255.255.255.0
ip nat inside
interface Wlan-GigabitEthernet0/0
switchport mode trunk
no ip address
interface Vlan1
no ip address
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool NAT x.x.x.x x.x.x.x netmask 255.255.255.248
ip nat inside source list 102 pool NAT overload
ip route 0.0.0.0 0.0.0.0 10.21.x.x
ip route 192.168.1.0 255.255.255.0 10.30.7.60
access-list 102 permit ip 10.30.2.0 0.0.0.255 any
access-list 102 permit ip 10.30.7.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
2 Accepted Solutions
We have had several different versions of what you want to accomplish. There was this one
I need the server to access the internet on 10.30.2.252 and block access to the network 10.30.7.0
Except My PC at 10.30.7.250 it should access the server
and there is this one
So I need that network 10.30.2.0 should have internet and block everything else
on network 10.30.7.0 Except My PC at 10.30.7.250
The changes suggested by Deepak should accomplish the first requirement. Also your version of LAN-Server-Block applied on the vlan 2 sub interface should have accomplished that. I am puzzled that you seem to indicate that neither approach worked.
If you really want the second requirement then you need to modify your ACL to look something like this
IP access-list ext LAN-Server-Block
5 permit ip host 10.30.2.200 host 10.30.7.250
10 deny ip 10.30.2.0 0.0.0.255 10.30.7.0 0.0.0.255
20 permit ip any any
and apply it in on gi0/1.2
Rick
Rick
Mr. Richard
It Works like charm you save me.
Many thanks to you and others who helps me
9 Replies 9
Deepak Kumar
I have some doubt.
Q::
What is your local subnet, which you want to block? and what is the default gateway for both subnets (server/local subnet)?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
The server on network 10.30.2.0 and access internet from the gateway 10.30.2.252  ( VLAN2 )
On the same router I have another network 10.30.7.0 with gateway 10.30.7.225 ( VLAN7 )
Is there any other settings to do the same task ??
5 permit ip host 10.30.7.250 host 10.30.2.200
10 deny ip 10.30.7.0 0.0.0.255 host 10.30.2.200
ip access-group LAN-Server-Block in
Deepak Kumar
Deepak Kumar,
The original post identified 2 objectives. The discussion so far has focused on the second one. I would like to comment on the first one which was
It seems to be saying that it wants to block the server from accessing the local network. The router is not able to block communication to the local network. To access the local network the server would simply arp for the destination and send the packets directly. The router plays no role in this and so is not able to block it. Or did I not understand the objective correctly.
[edit] I like the suggestion from Deepak. I originally thought that he had applied the access group on the vlan interface where the server is. But in reading the response again I realize that he is applying on the vlan interface of the server.
Rick
Rick
First Of all thanks for your concern
In fact I try "LAN-Server-Block" but nothing happened
Even I try this but also not work :-
10 deny ip 10.30.2.0 0.0.0.255 host 10.30.7.250
but also not work
The Problem is that I have a web server at 10.30.2.200 accessible from out side ( Cloud )
So I need to isolate it from internal network for security , at the same time it should have internet and
Can be accessed from my PC for management.
The server in network 10.30.2.0 ( VLAN2 ) with gateway 10.30.2.252
My Local Network is 10.30.7.0 with gateway 10.30.7.225
If this require any change on sub interfaces or have another design to do that no problem.
Rick
Rick
Mr. Richard
I am glad to know that you have solved your problem and that our suggestions pointed you toward the solution. Thank you for marking this discussion as solved. This will help other participants in the community to identify discussions that have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Rick
