Sub-interfaces
dacruzer1
Hi Everyone,
I have a 7204 VXR Router, all the ports are being used except for one Fa3/0.  I am about to create three networks, 192.168.3.0/24, 192.168.4.0/24 and 192.168.5.0/24.  I'm thinking of creating sub-interfaces on Fa3/0 but before I do that, does anyone know what is the maximum sub-interface I can create on a Fast Ethernet port and what is the dis-advantage of creating sub-interfaces?
Thanks.
vmiller
Level 7
Level 7
Read the following link on Router IDB's.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml
As far as disadvantages to using the sub interface idea, I'd suppose that high traffic volumes would give you issues.
Consider some form of throttling.
1] maximum sub-interface
---> Creating Sub-Interface on Fast Ether is nothing but associating with VLAN ID. The number of VLAN that you can create is the number of interface .
2]  dis-advantage of creating sub-interfaces
---> Dis-Advantage is nothing but you need to take care of CPU , It will utilize CPU as you will add number of interface.
Chetan Kumar
What is the command to show the current CPU utilization?
THanks
Alfred
Below are the command to see CPU utilization
1] show processes cpu
2] show processes cpu history
Chetan Kumar
