Subinterfaces error with two VLANs
Bruno Giorgio
Visitor
Hi all,
I'm running Packet Tracer 8.2.1, and I have the following network. Two VLANs (VLAN4 and VLAN5), one Switch 2960, and one Router 1941.
The VLAN networks are:
VLAN4 172.16.0.0/18   - PC IP 172.16.0.2  - Gateway 172.16.0.1
VLAN5 172.16.96.0/19 - PC IP 172.16.96.2 - Gateway 172.16.96.1
On the Switch, I have set as follows,
VLAN4 --> Fa0/x range 1 - 10  (the PC is connected to Fa0/1)
VLAN5 --> Fa0/x range 11-15  (the PC is connected to Fa0/11)
The Gig0/1 is the trunk connected to the Gig0/1 of the Router.
Now, on the Router I have set 2 subinterfaces with encapsulation dot1Q. No shutdown.
Every time I try to ping one PC on VLAN4 to another PC on VLAN5, for example
ping 172.16.96.2
it failed and on the Router I have the following error message.
"There is no subinterface with this vlan enabled"
Any idea about how to solve this?
Thanks in advance!
2 Accepted Solutions
M02@rt37
Hello @Bruno Giorgio,
Please share subinterface config.
It should look like:
interface gig 0/1.10
encapsulation dot1q 4
ip address 172.16.0.1 mask
interface gig 0/1.20
encapsulation dot1q 5
ip address 172.16.96.1 mask
Best regards
Encapsulation Vlan ID
is wrong for both
vlan 4 and 5
as interface ID does not matter but
encapsulation ID
does matter. Command
encapsulation dot1Q.x
will mark or assign all traffic to belong to
vlan x
Note that interface number does not have to match
encapsulation
number but makes sense when it does.
Change 10 to 4 and 20 to  5 like
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
Regards, ML
**Please Rate All Helpful Responses **
7 Replies 7
balaji.bandi
how is your sub interface config look like. make sure PC FW also disabled.
check below config need to be done for the sub-interface :
https://networklessons.com/cisco/ccna-routing-switching-icnd1-100-105/how-to-configure-router-on-a-stick
BB
Martin L
Zip your lab PT file and attach it here
M02@rt37
Best regards
Bruno Giorgio
Visitor
Hi  balaji.bandi ,
Thank you, I will read your link and let you know.
Hi Martin L ,
Sure. Attached you'll find my lab file.
is wrong for both
vlan 4 and 5
encapsulation ID
vlan x
encapsulation
Regards, ML
Bruno Giorgio
Visitor
You are great guys!
Thank you so much for your support!
You're very welcome @Bruno Giorgio.
Best regards
