subnets connection to server and to the internet.
luisdeanda12
Hello, I'm trying to divine my network but I'm having a hard time understanding how to do this. I want to separate departments on a class c network. All the computers need to talk back to the server and they also need to have an internet connection how can I accomplish this? I know that subnetting is a way to have better security in this is why I want to do it.
balaji.bandi
below high-level config that should work for you :
Router :
Config t
ip routing
interface Ethernet0/0
ip address x.x.x.x 255.255.255.X ( change this if this is DHCP)
ip nat outside
ip virtual-reassembly in
duplex auto
no shut
interface Ethernet0/1
no ip address
no shutdown
int fa0/1.1
description PC0 VLAN
encapsulation dot1q 10
ip address 192.168.1.1 255.255.255.224
ip nat inside
no shut
int fa0/1.2
encapsulation dot1q 20
description PC1 VLAN
ip address 192.168.1.33 255.255.255.224
ip nat inside
no shut
int fa0/1.3
description PC2 VLAN
encapsulation dot1q 30
ip address 192.168.1.65 255.255.255.224
ip nat inside
no shut
int fa0/1.4
description Server VLAN
encapsulation dot1q 40
ip address 192.168.1.225 255.255.255.224
ip nat inside
no shut
ip nat inside source list 100 interface Ethernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x ( ISP IP)
access-list 100 permit 192.168.1.0 0.0.0.31 any
access-list 100 permit 192.168.1.32 0.0.0.31 any
access-list 100 permit 192.168.1.64 0.0.0.31 any
access-list 100 permit 192.168.1.224 0.0.0.31 any
SWITCH :
config t
vlan 10
name PC0
vlan 20
name PC1
vlan 30
name PC2
vlan 40
name Server
interface fa0/1 (this is the port connecting to Router)
switchport mode trunk
no shut
interface fa0/1 (this where PC0 connected)
switchport mode access
switchport access vlan 10
interface fa0/1 ( PC1 connected)
switchport access vlan 20
interface fa0/3 ( PC 2 connected)
switchport access vlan 30
interface fa0/4 ( Server connected)
switchport access vlan 40
interface vlan 10
ip address 192.168.1.2 255.255.255.224
no shutdown
ip default-gateway 192.168.1.1
End device config
PC0 config with gateway 192.168.1.1
PC1 config with gateway 192.168.1.33
PC2 config with gateway 192.168.1.64
Server config with gateway 192.168.1.224
BB
Thanks so much can you tell me the reason why they have a different gateway? is not possible to just use the same gateway for all?
as per your post " want to separate departments on a class c network."you would like to use /27 for each segment, so that example.
if you like to have /24 network all in one VLAN.
below config should work :
Router :
Config t
ip routing
ip nat outside
duplex auto
no shut
ip nat inside
no shutdown
access-list 100 permit 192.168.1.0 0.0.0.255 any
SWITCH :
config t
vlan 10
name PC0
interface fa0/1 (this is the port connecting to Router - this can also be trunk if you looking expand later more vlan)
no shut
interface fa0/1
interface fa0/2
interface fa0/3
interface fa0/4
interface vlan 10
ip address 192.168.1.2 255.255.255.0
no shutdown
End device config ( make sure you configure subnet mask /24 instead of /27 - that is 255.255.255.0)
PC1 config with gateway 192.168.1.1
PC2 config with gateway 192.168.1.1
Server config with gateway 192.168.1.1
BB
