Suddendly SSH stopped working
asadgulzar90
Frequent Visitor
Frequent Visitor
I have configured ssh on 2 cisco routers in one branch. Both of them was working fine but one day suddenly one of the router's ssh stopped working. Now when i try to access by putty, immediately it gives me error message "Server unexpectedly closed the connection" .
Router is connected to ISP so it has public and private IP addresses, however i can ping the router from HQ and if try try to ssh that from from my HQ router, I can ssh through public IP but not through private IP.
I have also tried to do telnet but same issue.
7 Replies 7
Giuseppe Larosa
if you can perform SSH to the public address the SSH server is still working on the remote router.
Look for any configuration changes because this looks like more related to this a configuration change.
Hope to help
Giuseppe
I did nt chng config since it was working fine in the start.. As i said before that other router also working well.
Can you please tell if any specific thing to check ?
Hello ,
post the configuration of the affected devices make changes to protect you ( hide public addresses and passwords)
Have you got an IPSec  VPN LAN to LAN to reach the internal network  of the remote office?
Also NAT statements can have an effect.
Hope to help
Giuseppe
#sh runn
Building configuration...
Current configuration : 6599 bytes
! Last configuration change at 08:24:11 UTC Mon Aug 19 2019 by xyz
version 15.2
no service pad
hostname abc
boot-start-marker
boot-end-marker
enable secret 4 uHj.0741VttY5HilaEKF80G
aaa new-model
aaa authentication login VTY-login local enable
aaa session-id common
memory-size iomem 10
ip domain name xyz
ip name-server 0.0.0.0
ip name-server 8.8.8.8
ip cef
login block-for 65535 attempts 9 within 180
login quiet-mode access-class Strict-Access
no ipv6 cef
vtp mode transparent
vtp version 2
username xyz privilege 15 secret 4 gbaKmVqOXtI6WdwE9JhNI
controller VDSL 0
vlan 10
name Net_Infra
vlan 30
name Internet
vlan 31
name S_Internet
ip ftp username xyz
ip ftp password 7 013E07105A
ip ssh source-interface Vlan10
ip ssh version 2
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 10
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 31
no ip address
interface Vlan1
no ip address
interface Vlan10
ip address 10.10.10.2 255.255.255.252
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
interface Vlan30
no ip address
interface Vlan31
ip address 2.2.2.2 255.255.255.254
ip access-group Blocking_Ports_(External) in
ip nat outside
router ospf 10
network 10.10.10.0 0.0.0.3 area 0.0.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source Vlan10
ip flow-export version 9
ip flow-export destination x.x.x.x 60105
ip nat inside source list 1 interface Vlan31 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x
line con 0
logging synchronous
login authentication VTY-login
no modem enable
line aux 0
line vty 0 4
session-timeout 10
transport preferred ssh
transport input ssh
transport output ssh
scheduler allocate 20000 1000
ntp source Vlan10
ntp server x.x.x.x prefer
end
Hello ,
can you provide also the configuration of the access-lists
>> Strict-Access  used in login quiet command
>> 1 used for NAT
I do not see any VPN here and you have an ethernet handoff on Fas3 associated to SVI Vlan 31
I see you have also
This means outgoing SSH sessions started by this device will use the vlan 10 source address.
From what you have reported I don't see how you can connect on the LAN interface from the HQ office only SSH to Vlan31 public address should be possible.
You could use an
ip nat source inside static tcp 2.2.2.2 22330 10.10.10.1 22 extendable
Edit: the correct syntax requires the internal address first
ip nat source inside static tcp 10.10.10.1 22 2.2.2.2 22330
to make the SSH session to TCP port 22330 on public address  to be mapped to internal Vlan 10.
I am not sure this can work as this command is usually used for internal clients to make them reachable via internet using the public address on a specific port.
Hope to help
Giuseppe
Dear,
I tried to access that router from HQ router by ssh at public ip and it is giving me error now that "connection refused from remote host". (only this way was working before which stopped now itself)
Perhaps a good place to start is with the output of the command show ip ssh from the router.
Rick
Rick
