Summarization with RIPV2
berrug
Community Member
While working on my CCNA exam, I came across a Lab practicing which required me to use EIGRP on the routers. Then, I thought to myself ''Any chance I can use RIPV2 to summarize these routes?''.
I'm expected to summarize 192.168.1.0/2.0/3.0 networks on R1. I was not able to make this work using RIPV2 because I believe the summary route I used on R1 overlapped with 192.168.10.0 network. Is there anyway I can make this work by using RIPV2?
*The topology mentioned is below.
2 Accepted Solutions
jalejand
RIPv2 can only summarize in a Classful way, this means that you shouldn't be able to summarize 192.168.x.0 into 192.168.0.0 255.255.0.0 or 255.255.252.0 for a more exact matching summary.
Even though RFC 1918 says that class C addresses range is 192.168.0.0/16, CIDR classful mask for a class C is 255.255.255.0 = /24.
On a different approach, instead of using 192.168.1.0/2.0/3.0, you can summarize subnets that matches an entire class C range (/24), for example:
192.168.1.1/30
192.168.1.4/30
192.168.1.8/30
Summarized into 192.168.1.0/24, manual RIP summarization would allow this command.
Even though routes are overlapped, (thinking for a bit that summarization worked as expected on your scecnario) the router advertising 192.168.10.0/24 is advertising that exact same prefix while the other router is advertising a summary route. Traffic destined to 192.168.10.0/24 will use the longest prefix available that will be advertised by the originating router for 192.168.10.0/24, so it should not be any issue.
If you want, you can upload your packet tracer file so I can take a look at it.
Hi @berrug,
Review this way to implement summarization and RIPv2:
router rip
version 2
redistribute static <- With this command I propagate the summarized network
network 172.16.0.0 <- Here I only declare the network 172.16.5.0
ip classless
ip route 192.168.0.0 255.255.252.0 Serial0/0/0
5 Replies 5
luis_cordova
Hi @berrug,
You could summarize the indicated networks manually and declare the summarized network in the RIPv2 configuration
192.168.0000 0001.0 = 192.168.1.0/24
192.168.0000 0010.0 = 192.168.2.0/24
192.168.0000 0011.0 = 192.168.3.0/24
The summarized network would be: 192.168.0.0/22
192.168.0.0/22 would also encompass 192.168.0.0/24 (?) - if so, don't know if that's a concern
Thanks for the answers. My problem is when I use RIPv2 with manual summarization on R1, I can't ping the network 192.168.10.0 from any other network on the left side. Everything works fine when using Eigrp since I can use wildcard mask.
My Eigrp configuration on R1:
network 192.168.0.0  0.0.3.255
network 172.16.5.0
no auto-summary
I'm looking for a way to do this with RIPv2 so that any network on the left side (after getting summarized on R1) can ping the network 192.168.10.0. I don't know how to specify /22 while configuring Ripv2 as I can only type 192.168.0.0.
* I'm sorry about my broken English.
Hi @berrug,
router rip
version 2
ip classless
jalejand
192.168.1.1/30
192.168.1.4/30
192.168.1.8/30
