08-28-2020 06:17 AM
I need the switch command (Nexus) to show the ip address range assigned to each vlan on the network. For example Staff_vlan 100 what are the valid ip address for this vlan?
08-28-2020 06:23 AM
You can view show run interface vlan x ( it will show you subnet mask assigned to that VLAN) - that is the range for VLAN (is that works for you )
you can also show ip arp all | in vlanX will give you what is active ? - if this nexus is Layer 3 for this vlan.
=====️ Preenayamo Vasudevam ️=====
08-31-2020 10:47 PM
here is the cisco example
