Switch Portfast Timer
Rupesh Kashyap
My requirement is, whenever I connect desktop on the switch, then port should be in forwarding mode within 3 Second. If I enable Portfast, then how much second it will take to gain forwarding state ?
mahmoodmkl
Level 7
Level 7
It will immediately move in to forwarding state.
Mahmood
it means, it will bypass Max age timer )20sec )too.
Yes.
Mahmood
Yes.
Mahmood
