switch problem
csc010854800
all the lights on my cisco 2950 switch turns orange after 20 minutes of operation. for the first 20 minutes all the lights are green and switch works fine.
what can be the issue ? is it due to temprature problem or broadcast problem or anything else....???
yogesh,
It may be a broadcast problem. Assuming that it is a broadcast problem. While the problem is happening you have to pull the port off the switch one at a time and see the problem still exists or not if yes then pull the next port off. Till you found it.
Toshi
Leo Laohoo
Do all the lights turn orange or does each ports' light flash orange from time to time? If yes, then it's probably caused by line errors.
